HP t730 Thin Client 8GB 32GB FirePro Windows 10
Quicklinx: CH59WS00 Mfr#: J9B01ET#ABU
Goodbye add-ons, extras, and optional features. The HP t730 Thin Client, the world’s first thin client to drive quad UHD/4K displays natively, is ready to deploy in demanding environments right out of the box with an AMD quad-core processor, maximum interfaces, and OS and ISV choices.
Premium performer
Harness the power of AMD’s latest generation quad-core APU with Turbo Core technology that can throttle CPU action and kick it up to 3.6 GHz to run full VDI and local applications and render video to four displays.
Expand your view with quad displays
Create an efficient multi-monitor workspace with DisplayPort connections for up to four UHD/4K displays, or six displays with the discrete graphics card. Now you can enjoy a high pixel count, serious sharpness, and eye-popping details every day.
Integrated software sweetens the deal
Streamline deployments, enhance the user experience, and enable smooth device management with HP’s exclusive thin client software: HP Device Manager, HP Velocity, and HP Easy Shell.
Plan ahead with expansive I/O connections
Support your business now and in the future with serial, parallel, PS/2, and USB ports plus a PCI Express x8 low profile expansion slot.
  • Feels like face-to-face
    Experience broadened support for unified communications (UC) solutions such as Skype for Business.
  • Keep it simple
    Make it easy to deploy, manage, and maintain your install base with HP Device Manager.
  • True 3D delivery you have to see to believe
    Brace yourself for breakthrough loss-less video and graphics presentation from the cloud with HP True Graphics software.
  • Super-charged data delivery
    Improve wired and Wi-Fi network performance and the end user experience with HP Velocity software.
  • Quick. Clean. Streamlined
    Simplify the HP Thin Client Windows Embedded user experience with HP Easy Shell's customized interface and protection for targeted cloud control.
  • Any network, anytime
    Connect to any type of network with the standard RJ-45 interface or an optional Wi-Fi or Fiber Optic network adapter.
HP t730 - tower RX427BB 2.7 GHz - 8 GB - flash 32 GB - UK - TAA Compliant
Thin client - tower
1 x AMD RX427BB / 2.7 GHz (, up to 3.6 GHz, (Quad-Core)
Cache Memory
4 MB L2 Cache
Cache Per Processor
4 MB
RAM
8 GB (installed) / 16 GB (max) - DDR3L SDRAM
Hard Drive
Flash 32 GB - M.2
Optical Storage
No optical drive
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Controller
PCIe 3.0 x8 - AMD FirePro W2100 / AMD Radeon HD 9000
Video Memory
2 GB DDR3 SDRAM
1GbE
Keyboard
OS Provided
Windows 10 IoT Enterprise
6.7 cm x 22.1 cm x 24 cm
1.8 kg
TAA Compliant
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
AMD RX427BB
Clock Speed
2.7 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L2 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
8 GB / 16 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
SO-DIMM 204-pin
Slots
2 (Total) / 0 (empty)
Dual channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
Flash - M.2
1 x 32 GB
Multi-level cell (MLC)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Interface Type
PCIe 3.0 x8
Graphics Processor
Video Memory
2 GB DDR3 SDRAM
Video Interfaces
DisplayPort
Max Monitors Supported
6
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Mouse Name
HP USB Mouse
Optical
USB
Wake on LAN (WoL), PXE support
Slots
1 (total) / 0 (free) x M.2 Card , 2 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe 3.0 x16 (x8 mode)
6 x USB 2.0 (2 front, 4 rear) , 3 x USB 3.0 (2 front, 1 internal) , 6 x DisplayPort , 2 x PS/2 keyboard / mouse , 2 x serial , 1 x parallel , 1 x LAN (Gigabit Ethernet) , 2 x headphones/microphone (2 in front) , 1 x audio line-out , 1 x audio line-in
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, VCCI, EN 60950, UL 1950, CSA 22.2 No. 950, EN55022 Class B, low halogen
TAA Compliant
Power adapter
Power Provided
85 Watt
Operating System / Software
OS Provided
Windows 10 IoT Enterprise English
Sustainability Information
ENERGY STAR Certified
6.7 cm
22.1 cm
24 cm
1.8 kg
10 °C
10 - 90% (non-condensing)
