HP T730 AMD RX427BB 8GB 64GB Windows Embedded Std 7 Pro
Quicklinx: C14VWS00 Mfr#: J9A88EA#ABU
Processor Type: RX427BB
Operating System: Microsoft Windows Embedded Standard 7P 64-bit
Installed Memory: 8GB
Hard Drive Capacity: 64GB
Storage Type: Flash
£871.02 ex VAT
£1,045.22 inc VAT
Goodbye add-ons, extras, and optional features. The HP t730 Thin Client thanks to quad UHD/4K displays natively, is ready to deploy in demanding environments right out of the box with an AMD quad-core processor, maximum interfaces, and OS and ISV choices.
  • Premium performer
    Harness the power of AMD's latest generation quad-core APU with Turbo Core technology that can throttle CPU action and kick it up to 3.6 GHz to run full VDI and local applications and render video to four displays.
  • Expand your view with quad displays
    Create an efficient multi-monitor workspace with DisplayPort connections for up to four UHD/4K displays, or six displays with the discrete graphics card. Now you can enjoy a high pixel count, serious sharpness, and eye-popping details every day.
  • Integrated software sweetens the deal
    Streamline deployments, enhance the user experience, and enable smooth device management with HP's exclusive thin client software: HP Device Manager, HP Velocity, and HP Easy Shell.
  • Plan ahead with expansive I/O connections
    Support your business now and in the future with serial, parallel, PS/2, and USB ports plus a PCI Express x4 low profile expansion slot.
HP t730 - tower - RX427BB 2.7 GHz - 8 GB - 64 GB - QWERTY UK
Thin client - tower
1 x AMD RX427BB 2.7 GHz (3.6 GHz) (Quad-Core)
Cache Memory
4 MB L2 Cache
Cache Per Processor
4 MB
RAM
8 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800
Hard Drive
1 x flash 64 GB - M.2
Optical Storage
No optical drive
Graphics Controller
PCIe 3.0 x8 - AMD FirePro W2100
Video Memory
2 GB DDR3 SDRAM
GigE
OS Provided
6.7 cm x 22.1 cm x 24 cm
1.8 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
AMD RX427BB 2.7 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L2 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
8 GB / 16 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 0 (empty)
Dual channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
Flash - M.2
1 x 64 GB
Multi-level cell (MLC)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Interface Type
PCIe 3.0 x8
Graphics Processor
AMD FirePro W2100
Video Memory
2 GB DDR3 SDRAM
Video Interfaces
DisplayPort
Input Device
Keyboard
Keyboard
USB
Localization & Layout
QWERTY UK
Wake on LAN (WoL), PXE support
Slots
1 (total) / 0 (free) x M.2 Card , 2 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe 3.0 x16 - low-profile (x8 mode)
6 x USB 2.0 (2 front, 4 rear) , 3 x USB 3.0 (2 front, 1 internal) , 6 x DisplayPort , 2 x PS/2 keyboard / mouse , 2 x serial , 1 x parallel , 1 x LAN (Gigabit Ethernet) , 2 x headphones/microphone (2 in front) , 1 x audio line-out , 1 x audio line-in
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, VCCI, EN 60950, UL 1950, CSA 22.2 No. 950, EN55022 Class B
TAA Compliant
Power adapter
Nominal Voltage
Power Provided
85 Watt
Operating System / Software
OS Provided
Microsoft Windows Embedded Standard 7P 64-bit English
ENERGY STAR Certified
6.7 cm
22.1 cm
24 cm
1.8 kg
10 °C
10 - 90% (non-condensing)
HP T730 AMD RX427BB 8GB 64GB Windows Embedded Std 7 Pro Bundle deal on HP T730 AMD RX427BB 8GB 64GB Windows Embedded Std 7 Pro
£1,058.66
saving £8.33
£970.78
Storage Type: Flash
Processor Model: RX427BB
Type: Thin client
Case Style: Tower
Display: no
Optical Storage: None
Brand: HP
Price Range Ex VAT: 750 - 1000
