Product
HP T730 AMD RX427BB 8GB 64GB Windows Embedded Ind 10 Pro
Quicklinx: C150WS00 Mfr#: J9B03EA#ABU
Processor Type: R-series
Operating System: Windows 10 IOT Enterprise
Installed Memory: 8GB
Hard Drive Capacity: 64GB
Storage Type: Flash
£894.98 ex VAT
£1,073.97 inc VAT
Goodbye add-ons, extras, and optional features. The HP t730 Thin Client, HP's most powerful desktop thin client, is ready to deploy in demanding environments right out of the box with an AMD quad-core processor, maximum interfaces, OS and ISV choices, and native support for 4 UHD/4K displays.
  • Premium performer
    Harness the power of AMD's latest generation quad-core APU with Turbo Core technology that can throttle CPU action and kick it up to 3.6 GHz to run full VDI and local applications and render video to four displays.
  • Expand your view with quad displays
    Create an efficient multi-monitor workspace with DisplayPort connections for up to four UHD/4K displays, or six displays with the discrete graphics card. Now you can enjoy a high pixel count, serious sharpness, and eye-popping details every day.
  • Integrated software sweetens the deal
    Streamline deployments, enhance the user experience, and enable smooth device management with HP's exclusive thin client software: HP Device Manager, HP Velocity, and HP Easy Shell.
  • Plan ahead with expansive I/O connections
    Support your business now and in the future with serial, parallel, PS/2, and USB ports plus a PCI Express x4 low profile expansion slot.
HP t730 - tower - R-series RX427BB 2.7 GHz - 8 GB - 64 GB - UK layout
Thin client - tower
1 x AMD R-series RX427BB / 2.7 GHz (3.6 GHz) (Quad-Core)
Cache Memory
4 MB L2 Cache
Cache Per Processor
4 MB
RAM
8 GB (installed) / 16 GB (max) - DDR3L SDRAM
Hard Drive
1 x flash 64 GB - M.2
Optical Storage
No optical drive
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Controller
PCIe 3.0 x8 - AMD FirePro W2100 / AMD Radeon HD 9000
Video Memory
2 GB DDR3 SDRAM
GigE
OS Provided
6.7 cm x 22.1 cm x 24 cm
1.8 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L2 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
8 GB / 16 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
SO-DIMM 204-pin
Slots
2 (Total) / 0 (empty)
Dual channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
Flash - M.2
1 x 64 GB
Multi-level cell (MLC)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Interface Type
PCIe 3.0 x8
Graphics Processor
Video Memory
2 GB DDR3 SDRAM
Video Interfaces
DisplayPort
Max Monitors Supported
6
Input Device
Mouse, keyboard
Keyboard
Localization & Layout
Mouse
Mouse Name
HP USB Mouse
Optical
USB
Wake on LAN (WoL), PXE support
Slots
1 (total) / 0 (free) x M.2 Card , 2 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe 3.0 x16 - low-profile (x8 mode)
6 x USB 2.0 (2 front, 4 rear) , 3 x USB 3.0 (2 front, 1 internal) , 6 x DisplayPort , 2 x PS/2 keyboard / mouse , 2 x serial , 1 x parallel , 1 x LAN (Gigabit Ethernet) , 2 x headphones/microphone (2 in front) , 1 x audio line-out , 1 x audio line-in
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, VCCI, EN 60950, UL 1950, CSA 22.2 No. 950, EN55022 Class B, low halogen
TAA Compliant
Power adapter
Nominal Voltage
Power Provided
85 Watt
Operating System / Software
OS Provided
Windows 10 IOT Enterprise English
Software
Citrix ICA, HP Universal Print Driver, HP Remote Graphics Software, Microsoft Windows Media Player 12, HP Device Manager, Citrix Receiver, VMware Horizon View, Citrix HDX, HP Velocity, Microsoft RemoteFX, Microsoft Internet Explorer 11, VMware PCoIP, HP ThinUpdate, HP True Graphics, HP Easy Shell
ENERGY STAR Certified
6.7 cm
22.1 cm
24 cm
1.8 kg
10 °C
10 - 90% (non-condensing)
HP T730 AMD RX427BB 8GB 64GB Windows Embedded Ind 10 Pro Bundle deal on HP T730 AMD RX427BB 8GB 64GB Windows Embedded Ind 10 Pro
£1,077.49
saving £8.33
£989.99
Storage Type: Flash
Processor Model: RX427BB
Type: Thin client
Case Style: Tower
Display: no
Optical Storage: None
Brand: HP
Price Range Ex VAT: 750 - 1000
