Goodbye add-ons, extras, and optional features. The HP t730 Thin Client, HP's most powerful desktop thin client, is ready to deploy in demanding environments right out of the box with an AMD quad-core processor, maximum interfaces, OS and ISV choices, and native support for 4 UHD/4K displays.
Feels like face-to-face
Experience broadened support for unified communications (UC) solutions such as Skype for Business. -
Keep it simple
Make it easy to deploy, manage, and maintain your install base with HP Device Manager. -
True 3D delivery you have to see to believe
Brace yourself for breakthrough loss-less video and graphics presentation from the cloud with HP True Graphics software. -
Super-charged data delivery
Improve wired and Wi-Fi network performance and the end user experience with HP Velocity software. -
Quick. Clean. Streamlined
Simplify the HP Thin Client Windows Embedded user experience with HP Easy Shell's customized interface and protection for targeted cloud control. -
Any network, anytime
Connect to any type of network with the standard RJ-45 interface or an optional Wi-Fi or Fiber Optic network adapter.
- HP t730 - tower - R-series Embedded RX427BB 2.7 GHz - 8 GB - flash 64 GB - UK - TAA Compliant
- Thin client - tower
- Localisation
- Processor
- 1 x AMD R-series Embedded RX427BB / 2.7 GHz (, up to 3.6 GHz, (Quad-Core)
- Cache Memory
- 4 MB L2 Cache
- Cache Per Processor
- 4 MB
- RAM
- 8 GB (installed) / 16 GB (max) - DDR3L SDRAM
- Hard Drive
- Flash 64 GB - M.2
- Optical Storage
- No optical drive
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Controller
- PCIe 3.0 x8 - AMD FirePro W2100 / AMD Radeon HD 9000
- Video Memory
- 2 GB DDR3 SDRAM
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 IoT Enterprise
- Software Included
- Citrix ICA, HP Universal Print Driver, HP Remote Graphics Software, Microsoft Windows Media Player 12, HP Device Manager, Citrix Receiver, VMware Horizon View, Citrix HDX, HP Velocity, Microsoft RemoteFX, Microsoft Internet Explorer 11, VMware PCoIP, HP ThinUpdate, HP True Graphics, HP Easy Shell
- 6.7 cm x 22.1 cm x 24 cm
- 1.8 kg
- TAA Compliant
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- Tower
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD R-series Embedded RX427BB
- Clock Speed
- 2.7 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- L2 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- 8 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 0 (empty)
- Dual channel memory architecture
- Configuration Features
- 2 x 4 GB
Hard Drive
- Flash - M.2
- Capacity
- 1 x 64 GB
- Multi-level cell (MLC)
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Interface Type
- PCIe 3.0 x8
- Graphics Processor
- Video Memory
- 2 GB DDR3 SDRAM
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 6
Input Device
- Mouse, keyboard
Keyboard
- Localization & Layout
- UK
Mouse
- Mouse Name
- HP USB Mouse
- Technology
- Optical
- Interface
- USB
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Slots
- 1 (total) / 0 (free) x M.2 Card , 2 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe 3.0 x16 - low-profile (x8 mode)
- 6 x USB 2.0 (2 front, 4 rear) , 3 x USB 3.0 (2 front, 1 internal) , 6 x DisplayPort , 2 x PS/2 keyboard / mouse , 2 x serial , 1 x parallel , 1 x LAN (Gigabit Ethernet) , 2 x headphones/microphone (2 in front) , 1 x audio line-out , 1 x audio line-in
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, TUV GS, VCCI, EN 60950, UL 1950, CSA 22.2 No. 950, EN55022 Class B, low halogen
- TAA Compliant
- Power adapter
- Voltage Required
- Power Provided
- 85 Watt
Operating System / Software
- OS Provided
- Windows 10 IoT Enterprise English
- Software
Sustainability Information
- ENERGY STAR Certified
- 6.7 cm
- 22.1 cm
- 24 cm
- 1.8 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
Warranties (1)
Monitors (2)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £144.44 |
Other bundles (1)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
