Goodbye add-ons, extras, and optional features. The HP t730 Thin Client, HP's most powerful desktop thin client, is ready to deploy in demanding environments right out of the box with an AMD quad-core processor, maximum interfaces, OS and ISV choices, and native support for 4 UHD/4K displays.
Premium performer
Harness the power of AMD's latest generation quad-core APU with Turbo Core technology that can throttle CPU action and kick it up to 3.6 GHz to run full VDI and local applications and render video to four displays. -
Expand your view with quad displays
Create an efficient multi-monitor workspace with DisplayPort connections for up to four UHD/4K displays, or six displays with the discrete graphics card. Now you can enjoy a high pixel count, serious sharpness, and eye-popping details every day. -
Integrated software sweetens the deal
Streamline deployments, enhance the user experience, and enable smooth device management with HP's exclusive thin client software: HP Device Manager, HP Velocity, and HP Easy Shell. -
Plan ahead with expansive I/O connections
Support your business now and in the future with serial, parallel, PS/2, and USB ports plus a PCI Express x4 low profile expansion slot.
- HP t730 - tower - R-series Embedded RX427BB 2.7 GHz - 8 GB - flash 32 GB
- Thin client - tower
- Localisation
- Processor
- 1 x AMD R-series Embedded RX427BB / 2.7 GHz (3.6 GHz) (Quad-Core)
- Cache Memory
- 4 MB L2 Cache
- Cache Per Processor
- 4 MB
- RAM
- 8 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3L-12800
- Hard Drive
- Flash 32 GB - M.2
- Optical Storage
- No optical drive
- Graphics Controller
- PCIe 3.0 x8 - AMD FirePro W2100
- Video Memory
- 2 GB DDR3 SDRAM
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 IoT Enterprise for Thin Clients 64-bit Edition
- 6.7 cm x 22.1 cm x 24 cm
- 1.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- Tower
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD R-series Embedded RX427BB / 2.7 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- L2 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- 8 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3L-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 0 (empty)
- Dual channel memory architecture
- Configuration Features
- 2 x 4 GB
Hard Drive
- Flash - M.2
- Capacity
- 1 x 32 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Interface Type
- PCIe 3.0 x8
- Graphics Processor
- AMD FirePro W2100
- Video Memory
- 2 GB DDR3 SDRAM
- Video Interfaces
- DisplayPort
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Slots
- 1 (total) / 0 (free) x M.2 Card , 1 (total) / 0 (free) x PCIe 3.0 x16 (x8 mode)
- 6 x USB 2.0 (2 front, 4 rear) , 3 x USB 3.0 (2 front, 1 internal) , 4 x DisplayPort , 2 x PS/2 keyboard / mouse , 2 x serial , 1 x parallel , 1 x LAN (Gigabit Ethernet) , 2 x headphones/microphone (2 in front) , 1 x audio line-in , 1 x audio line-out
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, low halogen
- Power adapter
- Nominal Voltage
- Power Provided
- 85 Watt
Operating System / Software
- OS Provided
- Windows 10 IoT Enterprise for Thin Clients 64-bit Edition English
- ENERGY STAR Certified
- 6.7 cm
- 22.1 cm
- 24 cm
- 1.8 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
