Optimize your cloud-based deployments with the powerful, highly configurable, and long lifecycle HP t630 Thin Client. Support your business now and in the future with quad-core processing, dual UHD/4K display compatibility, and options for device and network connectivity and local storage.
Designed To Go Above And Beyond
Speed performance with an expertly engineered thin client driven by an embedded x86 quad-core system-on-a-chip. The integrated AMD Radeon graphics engine supports up to two UHD/4K displays for a fantastic media experience.
Bridge The Gap With Expansive Connectivity
Configure a precise deployment with legacy ports for your reliable peripherals, dual-channel DDR4 system memory, wired or optional wireless or fiber connectivity, and optional local dual flash memory up to 128 GB for separate, discrete storage.
Software With All The Extras, Minus The Extra Cost
Tailor your OS environment, remotely set up and deploy, boost Wi-Fi and network performance, and get local-quality multimedia on the cloud with exclusive HP value-added software: HP Device Manager, HP Velocity, HP True Graphics, and HP Easy Shell.
Legacy and future peripheral support
Keep the peripherals you know and trust and plan ahead with connections that include PS/2 and serial ports, an optional VGA output or second serial port, and convenient front and rear USB 3.0 and USB 2.0 ports. -
Next-level security
Protect data with VDI and cloud hosting, certified TPM, a BIOS designed to National Institute of Standards and Technology (NIST) specs, and Windows with Write Filter protection. -
Pro-class collaboration
Stay in contact with colleagues with support for unified communications (UC) solutions. -
If it's a network, you can connect to it
Go wired with standard RJ-45, wireless with an optional Wi-Fi/Bluetooth or external Wi-Fi antenna system, or connect to fiber with an optional Fiber Optic network adapter. -
Ready for browser-based productivity
Work with your choice of subscription-based SaaS solutions like Office 365. -
Add your favorite OS
Pick a familiar and reliable Windows or Linux OS and pair with your own ISV.
- HP t630 - tower - GX-420GI 2 GHz - 8 GB - flash 32 GB
- Thin client - tower
- Localisation
- Processor
- 1 x AMD GX-420GI 2 GHz (, up to 2.2 GHz, (Quad-Core)
- Processor Main Features
- AMD Turbo CORE Technology
- Cache Memory
- 2 MB L2 Cache
- Cache Per Processor
- 2 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Hard Drive
- Flash 32 GB - M.2
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon R6E
- Networking
- 1GbE, Bluetooth, 802.11a, 802.11b/g/n, Wi-Fi 5
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 IoT Enterprise 64-bit Edition
- Software Included
- Citrix ICA, Microsoft RDP, HP Universal Print Driver, HP Remote Graphics Software, Microsoft Windows Media Player 12, HP Device Manager, Citrix Receiver, VMware Horizon View, Citrix HDX, HP Velocity, Microsoft RemoteFX, Microsoft Internet Explorer 11, HP ThinUpdate, HP Easy Shell
- 12 cm x 22 cm x 25.1 cm
- 1.52 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- Tower
- Localisation
Processor / Chipset
- CPU
- AMD GX-420GI
- Clock Speed
- 2 GHz
- Max Turbo Speed
- 2.2 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- L2 Cache - 2 MB
- 2 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 0 (empty)
- Unbuffered
- Configuration Features
- 2 x 4 GB
Hard Drive
- Flash - M.2
- Capacity
- 1 x 32 GB
- Multi-level cell (MLC)
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R6E
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 2
Input Device
- Mouse
Mouse
- Interface
- USB
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 3168
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Wake on LAN (WoL), PXE support
- Slots
- 2 (total) / 0 (free) x SO-DIMM 260-pin , 1 M.2 Card - 2280 , 1 M.2 Card - 2242
- 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 4 x USB 2.0 (4 front, 2 rear) , 2 x USB 3.0 (2 in front) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x audio line-in/headphones
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, TUV GS, VCCI, EN 60950, UL 1950, CSA 22.2 No. 950, EN55022 Class B
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- Windows 10 IoT Enterprise 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- 12 cm
- 22 cm
- 25.1 cm
- 1.52 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
