Optimize your cloud-based deployments with the powerful, highly configurable, and long lifecycle HP t630 Thin Client. Support your business now and in the future with quad-core processing, dual UHD/4K display compatibility, and options for device and network connectivity and local storage.
Legacy and future peripheral support
Keep the peripherals you know and trust and plan ahead with connections that include PS/2 and serial ports, an optional VGA output or second serial port, and convenient front and rear USB 3.0 and USB 2.0 ports. -
Next-level security
Protect data with VDI and cloud hosting, certified TPM, a BIOS designed to National Institute of Standards and Technology (NIST) specs, and Windows with Write Filter protection. -
Pro-class collaboration
Stay in contact with colleagues with support for unified communications (UC) solutions. -
If it's a network, you can connect to it
Go wired with standard RJ-45, wireless with an optional Wi-Fi/Bluetooth or external Wi-Fi antenna system, or connect to fiber with an optional Fiber Optic network adapter. -
Ready for browser-based productivity
Work with your choice of subscription-based SaaS solutions like Office 365. -
Add your favorite OS
Pick a familiar and reliable Windows or Linux OS and pair with your own ISV.
- HP t630 - tower - GX-420GI 2 GHz - 4 GB - flash 16 GB - UK - TAA Compliant
- Thin client - tower
- Localisation
- Processor
- 1 x AMD GX-420GI 2 GHz (2.2 GHz) (Quad-Core)
- Processor Main Features
- AMD Turbo CORE Technology
- Cache Memory
- 2 MB L2 Cache
- Cache Per Processor
- 2 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Hard Drive
- Flash 16 GB - M.2 - multi-level cell (MLC)
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon R7E
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows Embedded Standard 7E 32-bit
- 12 cm x 22 cm x 25.1 cm
- 1.52 kg
- TAA Compliant
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- Tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD GX-420GI
- Clock Speed
- 2 GHz
- Max Turbo Speed
- 2.2 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- L2 Cache - 2 MB
- 2 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 1866 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 4 GB
Hard Drive
- Flash - M.2
- Capacity
- 1 x 16 GB
- Multi-level cell (MLC)
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R7E
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 2
Input Device
- Keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Slots
- 1 (total) / 0 (free) x M.2 Card - 2280 , 1 (total) / 1 (free) x M.2 Card - 2242
- 4 x USB 2.0 (2 front, 2 rear) , 3 x USB 3.0 (2 front, 1 internal) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x serial , 1 x headphones/microphone (1 in front) , 1 x audio line-out/line-in
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, UL, GS, CB, CCC, RoHS, ICES Class B, MEPS, KCC Class B, ERP, CECP, VCCI Class B, CISPR Class B
- TAA Compliant
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- Microsoft Windows Embedded Standard 7E 32-bit English
- 12 cm
- 22 cm
- 25.1 cm
- 1.52 kg
- Shipping Weight
- 4.1 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
Warranties (4)
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only | In Stock | £25.29 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years | In Stock | £49.36 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment | In Stock | £37.31 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year | In Stock | £18.06 |
Monitors (2)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £150.00 |
Other bundles (2)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HPE DisplayPort DVI-D Adapter | In Stock | £13.23 |
