Optimize your cloud-based deployments with the powerful, highly configurable, and long lifecycle HP t630 Thin Client. Support your business now and in the future with quad-core processing, dual UHD/4K display compatibility, and options for device and network connectivity and local storage.
Designed to go above and beyond
Speed performance with an expertly engineered thin client driven by an embedded x86 quad-core system-on-a-chip. The integrated AMD Radeon graphics engine supports up to two UHD/4K displays for a fantastic media experience. -
Bridge the gap with expansive connectivity
Configure a precise deployment with legacy ports for your reliable peripherals, dual-channel DDR4 system memory, wired or optional wireless or fiber connectivity, and optional local dual flash memory up to 128 GB for separate, discrete storage. -
Software with all the extras, minus the extra cost
Tailor your OS environment, remotely set up and deploy, boost Wi-Fi and network performance, and get local-quality multimedia on the cloud with exclusive HP value-added software: HP Device Manager, HP Velocity, HP True Graphics, and HP Easy Shell.
- HP t630 - tower - GX-420GI 2 GHz - 4 GB - flash 8 GB - TAA Compliant
- Thin client - tower
- Localisation
- Processor
- 1 x AMD GX-420GI 2 GHz (2.2 GHz) (Quad-Core)
- Processor Main Features
- AMD Turbo CORE Technology
- Cache Memory
- 2 MB L2 Cache
- Cache Per Processor
- 2 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-14900
- Hard Drive
- Flash 8 GB - M.2
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon R7E
- Networking
- GigE, Bluetooth, 802.11a, 802.11b/g/n, 802.11ac
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- HP ThinPro
- 12 cm x 22 cm x 25.1 cm
- 1.52 kg
- TAA Compliant
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- Tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD GX-420GI
- Clock Speed
- 2 GHz
- Max Turbo Speed
- 2.2 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- L2 Cache - 2 MB
- 2 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 1866 MHz
- Memory Specification Compliance
- PC4-14900
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- Flash - M.2
- Capacity
- 1 x 8 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R7E
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 2
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 3168
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Wake on LAN (WoL), PXE support
- IEEE 802.11ac
- Slots
- 1 (total) / 0 (free) x M.2 Card - 2280 , 1 (total) / 0 (free) x M.2 Card - 2242
- 4 x USB 2.0 (2 front, 2 rear) , 3 x USB 3.0 (2 front, 1 internal) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x serial , 1 x headphones/microphone , 1 x audio line-out/line-in
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, UL, GS, CB, CCC, RoHS, ICES Class B, MEPS, KCC Class B, ERP, CECP, VCCI Class B, CISPR Class B
- TAA Compliant
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- HP ThinPro English
- ENERGY STAR Certified
- 12 cm
- 22 cm
- 25.1 cm
- 1.52 kg
- Shipping Weight
- 4.1 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
Warranties (4)
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only | In Stock | £14.44 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years | In Stock | £62.60 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment | In Stock | £38.51 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year | In Stock | £17.67 |
Accessories (1)
HP B300 Mounting Bracket | In Stock | £32.48 |
Monitors (10)
HP EliteDisplay E243m 23.8" HD 5ms IPS Monitor | In Stock | £200.00 |
HP EliteDisplay E243m 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £203.04 |
HP EliteDisplay E273m 27" 1920x1080 5ms VGA HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £233.33 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP Z38c 37.5" 3840x1600 5ms HDMI DisplayPort USB-C Curved IPS LED Monitor | In Stock | £798.42 |
HP P24h G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £158.90 |
HP P22h G4 21.5" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £180.00 |
HP P27h G4 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £190.71 |
HP E23 G4 23" 1920x1080 5ms USB VGA HDMI FHD Monitor | In Stock | £199.16 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £191.77 |
Other bundles (4)
HPE DisplayPort To VGA Adapter | In Stock | £19.80 |
HP Display Port to VGA Adapter | In Stock | £19.80 |
HP PC Mounting Bracket For Monitors | In Stock | £48.94 |
HP Keyed Cable Lock 10mm | In Stock | £27.41 |
