Optimize your cloud-based deployments with the powerful, highly configurable, and long lifecycle HP t630 Thin Client. Support your business now and in the future with quad-core processing, dual UHD/4K display compatibility, and options for device and network connectivity and local storage.
Designed to go above and beyond
Speed performance with an expertly engineered thin client driven by an embedded x86 quad-core system-on-a-chip. The integrated AMD Radeon graphics engine supports up to two UHD/4K displays for a fantastic media experience. -
Bridge the gap with expansive connectivity
Configure a precise deployment with legacy ports for your reliable peripherals, dual-channel DDR4 system memory, wired or optional wireless or fiber connectivity, and optional local dual flash memory up to 128 GB for separate, discrete storage. -
Software with all the extras, minus the extra cost
Tailor your OS environment, remotely set up and deploy, boost Wi-Fi and network performance, and get local-quality multimedia on the cloud with exclusive HP value-added software: HP Device Manager, HP Velocity, HP True Graphics, and HP Easy Shell.
- HP t630 - tower - GX-420GI 2 GHz - 4 GB - flash 32 GB
- Thin client - tower
- Localisation
- Processor
- 1 x AMD GX-420GI 2 GHz (2.2 GHz) (Quad-Core)
- Processor Main Features
- AMD Turbo CORE Technology
- Cache Memory
- 2 MB L2 Cache
- Cache Per Processor
- 2 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-14900
- Hard Drive
- Flash 32 GB - M.2
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon R7E
- Networking
- GigE, Bluetooth, 802.11ac
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- HP ThinPro
- 12 cm x 22 cm x 25.1 cm
- 1.52 kg
- Pricing Type
- Promo
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- Tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD GX-420GI 2 GHz
- Max Turbo Speed
- 2.2 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- L2 Cache - 2 MB
- 2 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 1866 MHz
- Memory Specification Compliance
- PC4-14900
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- Flash - M.2
- Capacity
- 1 x 32 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R7E
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 2
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 3168
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11ac
- Wake on LAN (WoL), PXE support
- Slots
- 1 (total) / 0 (free) x M.2 Card - 2280 , 1 (total) / 0 (free) x M.2 Card - 2242
- 4 x USB 2.0 (2 front, 2 rear) , 3 x USB 3.0 (2 front, 1 internal) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x serial , 1 x headphones/microphone (1 in front) , 1 x audio line-out/line-in
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, UL, GS, CB, CCC, RoHS, ICES Class B, MEPS, KCC Class B, ERP, CECP, VCCI Class B, CISPR Class B
- Pricing Type
- Promo
- TAA Compliant
- Power adapter
- Nominal Voltage
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- HP ThinPro English
- ENERGY STAR Certified
- 12 cm
- 22 cm
- 25.1 cm
- 1.52 kg
- Shipping Weight
- 4.1 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
