HP T630 AMD Radeon GX-420GI 4GB 32GB Windows 10 Thin Client
Quicklinx: DZCXWS00 Mfr#: 2ZU99AT#ABU
Processor Type: GX-420GI
Operating System: HP ThinPro
Installed Memory: 4GB
Hard Drive Capacity: 32GB
Storage Type: Flash
£501.24 ex VAT
£601.48 inc VAT
Optimize your cloud-based deployments with the powerful, highly configurable, and long lifecycle HP t630 Thin Client. Support your business now and in the future with quad-core processing, dual UHD/4K display compatibility, and options for device and network connectivity and local storage.
  • Designed to go above and beyond
    Speed performance with an expertly engineered thin client driven by an embedded x86 quad-core system-on-a-chip. The integrated AMD Radeon graphics engine supports up to two UHD/4K displays for a fantastic media experience.
  • Bridge the gap with expansive connectivity
    Configure a precise deployment with legacy ports for your reliable peripherals, dual-channel DDR4 system memory, wired or optional wireless or fiber connectivity, and optional local dual flash memory up to 128 GB for separate, discrete storage.
  • Software with all the extras, minus the extra cost
    Tailor your OS environment, remotely set up and deploy, boost Wi-Fi and network performance, and get local-quality multimedia on the cloud with exclusive HP value-added software: HP Device Manager, HP Velocity, HP True Graphics, and HP Easy Shell.
HP t630 - tower - GX-420GI 2 GHz - 4 GB - flash 32 GB - UK
Thin client - tower
1 x AMD GX-420GI 2 GHz (2.2 GHz) (Quad-Core)
Processor Main Features
AMD Turbo CORE Technology
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-14900
Hard Drive
Flash 32 GB - M.2
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R7E
GigE, Bluetooth, 802.11ac
Keyboard
OS Provided
HP ThinPro
12 cm x 22 cm x 25.1 cm
1.52 kg
Pricing Type
Promo
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Tower
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
AMD GX-420GI 2 GHz
Max Turbo Speed
2.2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
1866 MHz
Rated Memory Speed
1866 MHz
Memory Specification Compliance
PC4-14900
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
Flash - M.2
1 x 32 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R7E
Video Interfaces
DisplayPort
Max Monitors Supported
2
Keyboard
Localization & Layout
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 3168
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11ac
Wake on LAN (WoL), PXE support
Slots
1 (total) / 0 (free) x M.2 Card - 2280 , 1 (total) / 0 (free) x M.2 Card - 2242
4 x USB 2.0 (2 front, 2 rear) , 3 x USB 3.0 (2 front, 1 internal) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x serial , 1 x headphones/microphone (1 in front) , 1 x audio line-out/line-in
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, UL, GS, CB, CCC, RoHS, ICES Class B, MEPS, KCC Class B, ERP, CECP, VCCI Class B, CISPR Class B
Pricing Type
Promo
TAA Compliant
Power adapter
Nominal Voltage
Power Provided
65 Watt
Operating System / Software
OS Provided
HP ThinPro English
ENERGY STAR Certified
12 cm
22 cm
25.1 cm
1.52 kg
Shipping Weight
4.1 kg
10 °C
10 - 90% (non-condensing)
Storage Type: Flash
Type: Thin client
Case Style: Tower
Display: not included
Optical Storage: None
Brand: HP
Price Range Ex VAT: 500 - 750
