Get a powerful and seamless desktop experience, enhanced security features, and premium client virtualization from the HP t620 PLUS Flexible Series Thin Client.
Get flexibility where you need it
Customize your thin client with everything you need and nothing you don't. Choose the configuration options and expansion capabilities that best fit your business and help ensure an ideal end user experience. -
Tailor your hardware and software performance to your exact requirements
Configure your deployment to provide a powerful seamless desktop experience for your end users without exceeding your budget. -
Customize security the way you want
Help protect your thin client environment with integrated and optional hardware and software security solutions, including: HP BIOS implemented to NIST guidelines, a TPM chipset, Fiber NIC communications, and lockable covers and ports. -
Designed to give you peace of mind
Reduce desktop service calls and product refreshes with a completely redesigned chassis that includes advanced passive cooling for fan-less support of quad-core processors.
- HP Flexible t620 PLUS - tower - GX-420CA 2 GHz - 4 GB - SSD 32 GB - UK - TAA Compliant
- Thin client - tower
- Localisation
- Processor
- 1 x AMD GX-420CA 2 GHz (Quad-Core)
- Cache Memory
- 2 MB L2 Cache
- Cache Per Processor
- 2 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800
- Hard Drive
- SSD 32 GB - SATA - mSATA
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon HD 8400E
- Audio Output
- Stereo - integrated
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows Embedded 8 Standard x64 Edition
- 6.5 cm x 22 cm x 24 cm
- 2.04 kg
- TAA Compliant
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Thin client
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Tower
- Built-in Devices
- Speaker
- Localisation
Processor / Chipset
- CPU
- AMD GX-420CA
- Clock Speed
- 2 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- L2 Cache - 2 MB
- 2 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total)
- Low-voltage
Hard Drive
- SSD - mSATA
- Capacity
- 1 x 32 GB
- Interface Type
- SATA
- Multi-level cell (MLC)
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Standard Keyboard
- Interface
- USB
- Localization & Layout
- UK
- Integrated
- Data Link Protocol
- Wake on LAN (WoL), DHCP support, PXE support
- Slots
- 1 (total) / 0 (free) x mSATA , 2 SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Mini Card , 1 (total) / 1 (free) x PCIe x16 (x4 mode) , 1 (total) / 1 (free) x M.2 Card
- 6 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 (2 in front) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x parallel , 1 x serial , 1 x VGA
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE
- TAA Compliant
- Power adapter
- Voltage Required
- Power Provided
- 85 Watt
Operating System / Software
- OS Provided
- Windows Embedded 8 Standard x64 Edition English
- OS Certified
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenApp 5, Microsoft Windows Server 2012
Sustainability Information
- ENERGY STAR Certified
- 6.5 cm
- 22 cm
- 24 cm
- 2.04 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
