HP t620 Flexible Thin Client AMD GX-217GA 4GB 8GB ThinPro 32-bit
Quicklinx: BD05WS00 Mfr#: G6F28AA#ABU
Processor Type: GX-217GA
Operating System: HP ThinPro 32-bit
Installed Memory: 4GB
Hard Drive Capacity: 8GB
Storage Type: SSD
£383.87 ex VAT
£460.64 inc VAT
Get a powerful and seamless desktop experience, enhanced security features, and premium client virtualization from the HP t620 Flexible Series Thin Client.
  • Get flexibility where you need it
    Customize your thin client with everything you need and nothing you don't. Choose the configuration options and expansion capabilities that best fit your business and help ensure an ideal end user experience.
  • Tailor your hardware and software performance to your exact requirements
    Configure your deployment to provide a powerful seamless desktop experience for your end users without exceeding your budget.
  • Customize security the way you want
    Help protect your thin client environment with integrated and optional hardware and software security solutions, including: HP BIOS implemented to NIST guidelines, a TPM chipset, Fiber NIC communications, and lockable covers and ports.
  • Designed to give you peace of mind
    Reduce desktop service calls and product refreshes with a completely redesigned chassis that includes advanced passive cooling for fan-less support of quad-core processors.
HP Flexible t620 - tower - GX-217GA 1.65 GHz - 4 GB - 8 GB - QWERTY UK
Thin client - tower
1 x AMD GX-217GA 1.65 GHz (Dual-Core)
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800
Hard Drive
1 x SSD 8 GB - SATA - M.2
Optical Storage
No optical drive
Graphics Controller
AMD Radeon HD 8280E
Audio Output
Stereo - integrated
GigE
OS Provided
HP ThinPro 32-bit
4 cm x 22 cm x 24 cm
1.36 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years
Thin client
Recommended Use
Small business, corporate business
Product Form Factor
Tower
Built-in Devices
Speaker
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total)
Low-voltage
Hard Drive
SSD - M.2
1 x 8 GB
Interface Type
SATA
Multi-level cell (MLC)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 8280E
Video Interfaces
DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
USB
Localization & Layout
QWERTY UK
Mouse
Optical
USB
Integrated
Wake on LAN (WoL), DHCP support, PXE support
Slots
1 (total) / 1 (free) x mSATA , 2 SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Mini Card , 1 (total) / 0 (free) x M.2 Card
6 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 (2 in front) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE
TAA Compliant
Power adapter
Nominal Voltage
Power Provided
65 Watt
Operating System / Software
OS Provided
HP ThinPro 32-bit English
OS Certified
Microsoft Windows Server 2003, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenApp 5, Microsoft Windows Server 2012
Software
Citrix ICA, Microsoft RDP, HP ThinState Tools, HP Connection Manager, HP Easy Tools, HP Device Manager, Citrix HDX, HP Velocity, Citrix Receiver 12.1.5, FreeRDP 1.0, Microsoft RemoteFX, HP Cloud Connection Manager, VMware Horizon View 2.1, HP TeemTalk Terminal Emulator 7.3.3, Mozilla Firefox 19, Citrix XenDesktop
ENERGY STAR Certified
4 cm
22 cm
24 cm
1.36 kg
10 °C
10 - 90% (non-condensing)
HP t620 Flexible Thin Client AMD GX-217GA 4GB 8GB ThinPro 32-bit Bundle deal on HP t620 Flexible Thin Client AMD GX-217GA 4GB 8GB ThinPro 32-bit
£569.09
saving £8.33
£483.04
Storage Type: SSD
Processor Model: GX-217GA
Type: Thin client
Case Style: Tower
Display: no
Optical Storage: None
Brand: HP
Price Range Ex VAT: 300 - 500
