HP t620 Flexible Thin Client AMD GX-217GA 4GB 64GB Windows Embedded Standard 7E 32-bit
Quicklinx: BCYKWS00 Mfr#: J9A42EA#ABU
Get a flexible, reliable desktop experience for your virtual network and knowledge base users with the HP t520 Flexible Thin Client.
  • Integrated, complete peripheral support
    Choose from a range of ports to support your business now and in the future.
  • Reliable connectivity options
    Pick the technology that's best for you-choose from two optional enterprise-class, factory-installed Wi-Fi NICs with internal antennas or optional integrated HP 100 Mbps Mini PCIe SC Fiber NIC.
  • Drive up to four displays
    Support single, dual or quad digital display setups, or choose legacy VGA.
  • High-performance processors
    Choose the dual-or quad-core AMD GX processor and AMD HD professional graphics combination best suited to your business.
  • Software with HP extras
    Pick the HP enhanced OS environment that's ideal for your budget and performance requirements.
HP Flexible t520 - tower - GX-212JC 1.2 GHz - 4 GB - SSD 64 GB - UK
Thin client - tower
1 x AMD GX-212JC 1.2 GHz (Dual-Core)
RAM
4 GB (installed) / 8 GB (max) - DDR3L SDRAM - PC3L-12800
Storage Controller
SATA
Hard Drive
SSD 64 GB - SATA - M.2
Optical Storage
No optical drive
GigE
Keyboard
OS Provided
Microsoft Windows Embedded Standard 7E 32-bit
Software Included
Citrix ICA, Microsoft RDP, Microsoft Firewall, HP Universal Print Driver, HP ThinState Tools, HP Connection Manager, Microsoft Windows Media Player 12, HP Easy Tools, File Based Write Filter, Enhanced Write Filter, HP Device Manager, Microsoft Internet Explorer 10, VMware Horizon View, Citrix HDX, HP Velocity, Microsoft RemoteFX, HP Cloud Connection Manager, Citrix Receiver 4.1, Citrix XenDesktop, HP Remote Graphics Software 7
4.51 cm x 20 cm x 20.01 cm
1.04 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Tower
Processor / Chipset
CPU
AMD GX-212JC
Clock Speed
1.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
RAM
Installed Size
4 GB / 8 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3L-12800
SO-DIMM 204-pin
Slots
1 (Total) / 0 (empty)
Low-voltage
Configuration Features
1 x 4 GB
Hard Drive
SSD - M.2
1 x 64 GB
Interface Type
SATA
Multi-level cell (MLC)
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA, DisplayPort
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
USB
Localization & Layout
Slots
1 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe Mini Card
2 x USB 3.0 (2 in front) , 4 x USB 2.0 , 2 x DisplayPort , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, VCCI, EN 60950, UL 1950, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE, low halogen
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
Microsoft Windows Embedded Standard 7E 32-bit English
Software
Sustainability Information
ENERGY STAR Certified
4.51 cm
20 cm
20.01 cm
1.04 kg
10 °C
10 - 90% (non-condensing)
