HP t620 Flexible Thin Client AMD GX-217GA 4GB 16GB Windows Embedded Standard 7E 32-bit
Quicklinx: BCZHWS00 Mfr#: F5A58AA#ABU
Processor Type: GX-217GA
Operating System: Microsoft Windows Embedded Standard 7E 32-bit
Installed Memory: 4GB
Hard Drive Capacity: 16GB
Storage Type: SSD
  • IEEE 802.11n
£457.90 ex VAT
£549.48 inc VAT
Get a powerful and seamless desktop experience, enhanced security features, and premium client virtualization from the HP t620 Flexible Series Thin Client.
  • Get flexibility where you need it
    Customize your thin client with everything you need and nothing you don't. Choose the configuration options and expansion capabilities that best fit your business and help ensure an ideal end user experience.
  • Tailor your hardware and software performance to your exact requirements
    Configure your deployment to provide a powerful seamless desktop experience for your end users without exceeding your budget.
  • Customize security the way you want
    Help protect your thin client environment with integrated and optional hardware and software security solutions, including: HP BIOS implemented to NIST guidelines, a TPM chipset, Fiber NIC communications, and lockable covers and ports.
  • Designed to give you peace of mind
    Reduce desktop service calls and product refreshes with a completely redesigned chassis that includes advanced passive cooling for fan-less support of quad-core processors.
HP Flexible t620 - tower - GX-217GA 1.65 GHz - 4 GB - 16 GB
Thin client - tower
1 x AMD GX-217GA 1.65 GHz (Dual-Core)
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800
Hard Drive
1 x SSD 16 GB - SATA
Optical Storage
No optical drive
Graphics Controller
AMD Radeon HD 8280E
Audio Output
Stereo - integrated
GigE, 802.11a, 802.11b/g/n
OS Provided
4 cm x 22 cm x 24 cm
1.36 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - parts and labour - 3 years
Thin client
Recommended Use
Small business, corporate business
Product Form Factor
Tower
Built-in Devices
Speaker
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total)
Low-voltage
Hard Drive
SSD
1 x 16 GB
Interface Type
SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 8280E
Video Interfaces
DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
USB
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Wake on LAN (WoL), DHCP support, PXE support
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Slots
1 (total) / 0 (free) x mSATA , 2 SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe Mini Card
6 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 (2 in front) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE
TAA Compliant
Power adapter
Nominal Voltage
Power Provided
65 Watt
Operating System / Software
OS Provided
OS Certified
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenApp 5, Microsoft Windows Server 2012
Software
Citrix ICA, Microsoft RDP, Microsoft Firewall, HP Universal Print Driver, HP ThinState Tools, Citrix XenDesktop Standard Edition, HP Connection Manager, Microsoft Windows Media Player 12, HP Easy Tools, File Based Write Filter, Enhanced Write Filter, HP Device Manager, Microsoft Internet Explorer 9.0, HP TeemTalk Terminal Emulator 7.3, LogOn Manager, Citrix HDX, Microsoft Remote Desktop Protocol (RDP) Client 8, HP Velocity, HP Remote Graphics Software 6, Microsoft RemoteFX, Citrix Receiver 4.0, HP Cloud Connection Manager, VMware Horizon View 5.4
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
4 cm
22 cm
24 cm
1.36 kg
10 °C
10 - 90% (non-condensing)
HP t620 Flexible Thin Client AMD GX-217GA 4GB 16GB Windows Embedded Standard 7E 32-bit Bundle deal on HP t620 Flexible Thin Client AMD GX-217GA 4GB 16GB Windows Embedded Standard 7E 32-bit
£640.41
saving £8.33
£550.93
Storage Type: SSD
Processor Model: GX-217GA
Type: Thin client
Case Style: Tower
Display: no
Optical Storage: None
Brand: HP
Price Range Ex VAT: 300 - 500
