Get a powerful and seamless desktop experience, enhanced security features, and premium client virtualization from the HP t620 Flexible Series Thin Client.
Integrated, complete peripheral support
Choose from a range of ports to support your business now and in the future. -
Reliable connectivity options
Pick the technology that's best for you-choose from two optional enterprise-class, factory-installed Wi-Fi NICs with internal antennas or optional integrated HP 100 Mbps Mini PCIe SC Fiber NIC. -
Drive up to four displays
Support single, dual or quad digital display setups, or choose legacy VGA. -
High-performance processors
Choose the dual-or quad-core AMD GX processor and AMD HD professional graphics combination best suited to your business. -
Software with HP extras
Pick the HP enhanced OS environment that's ideal for your budget and performance requirements.
- HP Flexible t620 - tower - GX-217GA 1.65 GHz - 4 GB - SSD 16 GB - TAA Compliant
- Thin client - tower
- Localisation
- Processor
- 1 x AMD GX-217GA 1.65 GHz (Dual-Core)
- Cache Memory
- 1 MB L2 Cache
- Cache Per Processor
- 1 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800
- Hard Drive
- SSD 16 GB - SATA
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon HD 8280E
- Audio Output
- Stereo - integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows Embedded Standard 7E 32-bit
- Software Included
- Citrix ICA, Microsoft RDP, Microsoft Firewall, HP Universal Print Driver, HP ThinState Tools, Citrix XenDesktop Standard Edition, HP Connection Manager, Microsoft Windows Media Player 12, HP Easy Tools, File Based Write Filter, Enhanced Write Filter, HP Device Manager, Microsoft Internet Explorer 9.0, HP TeemTalk Terminal Emulator 7.3, LogOn Manager, Citrix HDX, Microsoft Remote Desktop Protocol (RDP) Client 8, HP Velocity, HP Remote Graphics Software 6, Microsoft RemoteFX, Citrix Receiver 4.0, HP Cloud Connection Manager, VMware Horizon View 5.4
- 4 cm x 22 cm x 24 cm
- 1.36 kg
- Pricing Type
- Promo
- TAA Compliant
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - parts and labour - 3 years
- Thin client
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Tower
- Localisation
Processor / Chipset
- CPU
- AMD GX-217GA
- Clock Speed
- 1.65 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- L2 Cache - 1 MB
- 1 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total)
- Low-voltage
Hard Drive
- SSD
- Capacity
- 1 x 16 GB
- Interface Type
- SATA
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Standard Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Integrated
- Data Link Protocol
- Wake on LAN (WoL), DHCP support, PXE support
- Slots
- 1 (total) / 0 (free) x mSATA , 2 SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Mini Card
- 6 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 (2 in front) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE
- Pricing Type
- Promo
- TAA Compliant
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- OS Certified
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenApp 5, Microsoft Windows Server 2012
- Software
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 4 cm
- 22 cm
- 24 cm
- 1.36 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
