HP T610 Smart Zero ES Flex Thin Client
Quicklinx: 9DFFWS00 Mfr#: E4T98AA#ABU
HP t610 Flexible Thin Client delivers added security, broad expansion options and a PC-like multimedia experience for virtualized desktops. A flexible solution with a powerful boost in performance.
  • Advanced technology, high-end deployment
    The HP t610 Flexible Series Thin Clients deliver a true, PC-like experience for virtualized desktop environments. AMD's APU technology, combining dual core processor with AMD HD 6320 graphics.
  • Eco-highlights
    HP t610 Flexible Series Thin Client is built with the environment in mind.
HP Flexible t610 - tower - G-T56N 1.65 GHz - 4 GB - flash 1 GB
Thin client - tower
1 x AMD G-T56N 1.65 GHz (Dual-Core)
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 4 GB (max) - DDR3 SDRAM - PC3-12800
Hard Drive
Flash 1 GB
Optical Storage
No optical drive
Graphics Controller
AMD Radeon HD 6320
Audio Output
Stereo - integrated
1GbE
OS Provided
HP Smart Zero Technology
Software Included
Rdesktop 1.6, Microsoft RDP 6.0, HP ThinState Tools, HP Connection Manager, Citrix ICA 12.0, HP Easy Tools, HP Device Manager, HP TeemTalk Terminal Emulator 7, VMware View Manager 4.6
4 cm x 22 cm x 24 cm
1.49 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Thin client
Recommended Use
Small business, corporate business
Product Form Factor
Tower
Processor / Chipset
CPU
AMD G-T56N
Clock Speed
1.65 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Chipset Type
AMD A55E
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
4 GB / 4 GB (max)
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total)
Hard Drive
Flash
1 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 6320
Video Interfaces
VGA, DVI, DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Input Device
Mouse, keyboard
Integrated
Wake on LAN (WoL), DHCP support, PXE support
IEEE 802.1x
Slots
2 SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Half Mini Card
4 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 , 1 x DVI-I , 1 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in/microphone (1 in front) , 1 x audio line-out/headphones (1 in front)
DVI-VGA adapter
Theft/Intrusion Protection
FCC Class B certified, TUV GS, VCCI, EN 60950, UL 1950, ZH1 618, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
OS Certified
Microsoft Windows Server 2003, Microsoft Windows Server 2003 Terminal Server, Microsoft Windows Server 2008 Terminal Server, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenDesktop 4, Citrix XenApp 5, Citrix XenApp 6
Software
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
4 cm
22 cm
24 cm
1.49 kg
10 °C
10 - 90% (non-condensing)
