HP T530 Thin Client AMD GX-215JJ 8GB 128GB Windows 10 Pro
Quicklinx: DX00WS00 Mfr#: Y5X66EA#ABU
Processor Type: GX-215JJ
Operating System: Windows 10 IoT Enterprise
Installed Memory: 8GB
Hard Drive Capacity: 128GB
Storage Type: Flash
  • IEEE 802.11n
£523.49 ex VAT
£628.18 inc VAT
Upgrade your cloud computing environment with the first HP thin client made for the office of the future. Elegantly designed with essential performance and reliability, the HP t530 Thin Client meets the needs of today and the growing demands of tomorrow.
  • Elevate your office space
    The HP t530 has raised the stakes for thin client design. Get all the features you need in an exceptionally modern, compact device. And with quiet, solid-state operation and multiple deployment options, it fits perfectly into any workspace.
  • Handle cloud computing workloads with ease
    Easily tackle all your computing demands with the newest AMD thin client technology. Whether doing offloaded processing or graphics rendering, you'll get an amazing PC-like experience in the cloud.
  • Future proof your office
    Finally a thin client built for today and tomorrow. Packed with flash storage, memory and connectivity options, along with multiple ports including USB-C to support both old and new peripherals, your transition into the future will be seamless..
HP t530 - tower - GX-215JJ 1.5 GHz - 8 GB - 128 GB
Thin client - tower
1 x AMD GX-215JJ 1.5 GHz (2 GHz) (Dual-Core)
Processor Main Features
AMD Turbo CORE Technology
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
8 GB (installed) / 16 GB (max) DDR4 SDRAM - non-ECC - PC4-14900
Hard Drive
1 x flash 128 GB - M.2
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R2E
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
OS Provided
Windows 10 IOT Enterprise
3.5 cm x 20 cm x 20 cm
962.8 g
Environmental Standards
ENERGY STAR Qualified
Thin client
Product Form Factor
Tower
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
8 GB / 16 GB (max)
Effective Memory Speed
1866 MHz
Rated Memory Speed
1866 MHz
Memory Specification Compliance
PC4-14900
SO-DIMM 260-pin
Slots
1 (Total) / 0 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
Flash - M.2
1 x 128 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R2E
Video Interfaces
DisplayPort
Max Monitors Supported
2
Input Device
Mouse
Mouse
Optical
USB
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Wake on LAN (WoL), DHCP support, PXE support, dual stream (2x2)
IEEE 802.1x
Slots
1 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card
3 x USB 3.1 Gen 1 (1 front, 2 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x USB 2.0 (2 rear) , Headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
UL, VCCI, GS, CB, CCC, FCC, RoHS, KCC, WEEE, CISPR, ICES, MEPS, ERP, CECP, EMI, low halogen
Power adapter
Nominal Voltage
Power Provided
45 Watt
Operating System / Software
OS Provided
Windows 10 IOT Enterprise English
OS Certified
HP ThinPro, Microsoft Windows Embedded Standard 7E, HP Smart Zero Core, Windows 10 IOT Enterprise
ENERGY STAR Certified
3.5 cm
20 cm
20 cm
962.8 g
10 °C
10 - 90% (non-condensing)
HP T530 Thin Client AMD GX-215JJ 8GB 128GB Windows 10 Pro Bundle deal on HP T530 Thin Client AMD GX-215JJ 8GB 128GB Windows 10 Pro
£622.66
Storage Type: Flash
Type: Thin client
Case Style: Tower
Display: not included
Optical Storage: None
Brand: HP
Price Range Ex VAT: 500 - 750
