HP T530 AMD Radeon R2E GX-215JJ 32GB Thin Client
Quicklinx: DZS7WS00 Mfr#: 3JH75EA#ABU
Processor Type: GX-215JJ
Operating System: Windows 10 IOT Enterprise 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 32GB
Storage Type: Flash
  • IEEE 802.11n
£466.13 ex VAT
£559.35 inc VAT
Upgrade your cloud computing environment with the first HP thin client made for the office of the future. Elegantly designed with essential performance and reliability, the HP t530 Thin Client meets the needs of today and the growing demands of tomorrow.
  • Elevate your office space
    The HP t530 has raised the stakes for thin client design. Get all the features you need in an exceptionally modern, compact device. And with quiet, solid-state operation and multiple deployment options, it fits perfectly into any workspace.
  • Handle cloud computing workloads with ease
    Easily tackle all your computing demands with the newest AMD thin client technology. Whether doing offloaded processing or graphics rendering, you'll get an amazing PC-like experience in the cloud.
  • Future proof your office
    Finally a thin client built for today and tomorrow. Packed with flash storage, memory and connectivity options, along with multiple ports including USB-C to support both old and new peripherals, your transition into the future will be seamless..
HP t530 - tower - GX-215JJ 1.5 GHz - 8 GB - 32 GB
Thin client - tower
1 x AMD GX-215JJ 1.5 GHz (2 GHz) (Dual-Core)
Processor Main Features
AMD Turbo CORE Technology
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
8 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC - PC4-14900
Hard Drive
1 x flash 32 GB - M.2
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R2E
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
OS Provided
3.5 cm x 20 cm x 20 cm
962.8 g
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
8 GB / 16 GB (max)
Effective Memory Speed
1866 MHz
Rated Memory Speed
1866 MHz
Memory Specification Compliance
PC4-14900
SO-DIMM 260-pin
Slots
1 (Total) / 0 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
Flash - M.2
1 x 32 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R2E
Video Interfaces
DisplayPort
Max Monitors Supported
2
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Wake on LAN (WoL), DHCP support, PXE support
IEEE 802.1x
Slots
1 (total) / 0 (free) x M.2 Card
3 x USB 3.1 Gen 1 (1 front, 2 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x USB 2.0 (2 rear) , Headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
UL, VCCI, GS, CB, CCC, FCC, RoHS, KCC, WEEE, CISPR, ICES, MEPS, ERP, CECP, EMI, low halogen
Power adapter
Nominal Voltage
Power Provided
45 Watt
Operating System / Software
OS Provided
Windows 10 IOT Enterprise 64-bit Edition English
OS Certified
HP ThinPro, Microsoft Windows Embedded Standard 7E, HP Smart Zero Core, Windows 10 IOT Enterprise
Software
HP Universal Print Driver, HP Easy Tools, HP Device Manager, HP Velocity, HP Smart Zero Client, Microsoft Internet Explorer 11, HP ThinUpdate, HP Easy Shell, Microsoft SCCM/EDM-agent
3.5 cm
20 cm
20 cm
962.8 g
10 °C
10 - 90% (non-condensing)
HP T530 AMD Radeon R2E GX-215JJ 32GB Thin Client Bundle deal on HP T530 AMD Radeon R2E GX-215JJ 32GB Thin Client
£651.35
saving £8.33
£565.30
Storage Type: Flash
Type: Thin client
Case Style: Tower
Optical Storage: None
Brand: HP
Price Range Ex VAT: 300 - 500
