Upgrade your cloud computing environment with the first HP thin client made for the office of the future. Elegantly designed with essential performance and reliability, the HP t530 Thin Client meets the needs of today and the growing demands of tomorrow.
Elevate your office space
The HP t530 has raised the stakes for thin client design. Get all the features you need in an exceptionally modern, compact device. And with quiet, solid-state operation and multiple deployment options, it fits perfectly into any workspace. -
Handle cloud computing workloads with ease
Easily tackle all your computing demands with the newest AMD thin client technology. Whether doing offloaded processing or graphics rendering, you'll get an amazing PC-like experience in the cloud. -
Future proof your office
Finally a thin client built for today and tomorrow. Packed with flash storage, memory and connectivity options, along with multiple ports including USB-C to support both old and new peripherals, your transition into the future will be seamless..
- HP t530 - tower - GX-215JJ 1.5 GHz - 4 GB - flash 32 GB
- Thin client - tower
- Localisation
- Processor
- 1 x AMD GX-215JJ 1.5 GHz (2 GHz) (Dual-Core)
- Processor Main Features
- AMD Turbo CORE Technology
- Cache Memory
- 1 MB L2 Cache
- Cache Per Processor
- 1 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC - PC4-14900
- Hard Drive
- Flash 32 GB - M.2
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon R2E
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 IoT Enterprise
- 3.5 cm x 20 cm x 20 cm
- 962.8 g
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- Tower
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD GX-215JJ 1.5 GHz
- Max Turbo Speed
- 2 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- L2 Cache - 1 MB
- 1 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 1866 MHz
- Memory Specification Compliance
- PC4-14900
- Form Factor
- SO-DIMM 260-pin
- Slots
- 1 (Total) / 0 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- Flash - M.2
- Capacity
- 1 x 32 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R2E
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 2
- Data Link Protocol
- Wake on LAN (WoL), DHCP support, PXE support
- IEEE 802.1x
- Slots
- 1 (total) / 0 (free) x M.2 Card
- 1 x USB-C 3.1 Gen 1 (1 in front) , 3 x USB 3.1 Gen 1 (1 front, 2 rear) , 2 x USB 2.0 , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , Headphones/microphone (1 in front)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- UL, VCCI, GS, CB, CCC, FCC, RoHS, KCC, WEEE, CISPR, ICES, MEPS, ERP, CECP, EMI
- Power adapter
- Voltage Required
- Power Provided
- 45 Watt
Operating System / Software
- OS Provided
- Windows 10 IoT Enterprise English
- ENERGY STAR Certified
- 3.5 cm
- 20 cm
- 20 cm
- 962.8 g
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
Warranties (4)
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only | In Stock | £14.44 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years | In Stock | £62.60 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment | In Stock | £38.51 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year | In Stock | £19.44 |
Accessories (1)
HP B300 Mounting Bracket | In Stock | £32.48 |
Monitors (9)
HP EliteDisplay E243m 23.8" HD 5ms IPS Monitor | In Stock | £177.78 |
HP EliteDisplay E243m 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £182.09 |
HP EliteDisplay E273m 27" 1920x1080 5ms VGA HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £219.97 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP Z32 31.5" 3840x2160 14ms HDMI DisplayPort IPS LED Monitor | In Stock | £976.56 |
HP Z38c 37.5" 3840x1600 5ms HDMI DisplayPort USB-C Curved IPS LED Monitor | In Stock | £833.33 |
HP P24h G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £154.49 |
HP P27h G4 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £190.71 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £164.13 |
Other bundles (4)
HPE DisplayPort To VGA Adapter | In Stock | £20.25 |
HPE DisplayPort to VGA Adapter | In Stock | £22.69 |
HP PC Mounting Bracket For Monitors | In Stock | £48.94 |
HP Keyed Cable Lock 10mm | In Stock | £27.41 |
