The next-generation thin client
Introducing incredible durability engineered around an AMD GX-215JJ dual-core 1.5 – 2.0 GHz SoC with Radeon™ R2E graphics and a fully solid-state fan-less design. Welcome to a future-focused desktop thin client experience.
Protection against system threats
Security and performance go hand in hand with newly designed embedded operating systems and Trusted Platform Module hardware. Virtualized cloud computing ensures against system threats.
Support from every angle.
Support comes naturally when you have a choice of USB ports, including USB-C™, serial and VGA ports. And with two DisplayPort™ outputs, we’ve got support covered, from every angle.
Stay connected
With an embedded GbE network adapter and optional Wi-Fi adapter with Bluetooth® and choice of internal or external antenna systems, connectivity is covered to meet your every need and deployment scenario.
Memory to serve your needs
With solid-state flash memory storage options up to 512 GB, and SDRAM system memory up to 16 GB, performance is assured now and in the future.
Choose your favorite OS.
Now you can choose between a Windows® operating system or HP’s ThinPro with Smart Zero Core. These operating systems enable connecting to your own ISV with Citrix®, VMware®, and Microsoft®, or let you go straight to the Cloud with included browsers.
Value, with none of the extra cost
Extra value doesn’t mean extra cost. You get it all when you tailor your OS environment. With exclusive HP value-added Thin Client software, it’s perfect for your performance and your pocket.
Introducing incredible durability engineered around an AMD GX-215JJ dual-core 1.5 – 2.0 GHz SoC with Radeon R2E graphics and a fully solid-state fan-less design. Welcome to a future-focused desktop thin client experience. -
Security and performance go hand in hand with newly designed embedded operating systems and Trusted Platform Module hardware. Virtualized cloud computing ensures against system threats. -
Support comes naturally when you have a choice of USB ports, including USB-C , serial and VGA ports. And with two DisplayPort outputs, we've got support covered, from every angle. -
Stay connected
With an embedded GbE network adapter and optional Wi-Fi adapter with Bluetooth and choice of internal or external antenna systems, connectivity is covered to meet your every need and deployment scenario. -
With solid-state flash memory storage options up to 512 GB, and SDRAM system memory up to 16 GB, performance is assured now and in the future. -
Now you can choose between a Windows operating system or HP's ThinPro with Smart Zero Core. These operating systems enable connecting to your own ISV with Citrix , VMware , and Microsoft , or let you go straight to the Cloud with included browsers.
- HP t530 - tower - GX-215JJ 1.5 GHz - 8 GB - flash 32 GB - UK
- Thin client - tower
- Localisation
- Processor
- 1 x AMD GX-215JJ 1.5 GHz (2 GHz) (Dual-Core)
- Processor Main Features
- AMD Turbo CORE Technology
- Cache Memory
- 1 MB L2 Cache
- Cache Per Processor
- 1 MB
- RAM
- 8 GB (installed) / 16 GB (max) - DDR4 SDRAM
- Hard Drive
- Flash 32 GB - M.2 - multi-level cell (MLC)
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon R2E
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 IoT Enterprise for Thin Clients 64-bit Edition
- 3.5 cm x 20 cm x 20 cm
- 962.8 g
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- Tower
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD GX-215JJ 1.5 GHz
- Max Turbo Speed
- 2 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- L2 Cache - 1 MB
- 1 MB
RAM
- Installed Size
- 8 GB / 16 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 1866 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 1 (Total) / 0 (empty)
- Configuration Features
- 1 x 8 GB
Hard Drive
- Flash - M.2
- Capacity
- 1 x 32 GB
- Multi-level cell (MLC)
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R2E
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 2
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
- Data Link Protocol
- Wake on LAN (WoL), DHCP support, PXE support
- IEEE 802.1x
- Slots
- 1 (total) / 0 (free) x M.2 Card
- 2 x USB 3.1 Gen 1 , 1 x USB-C 3.1 (1 in front) , 2 x USB 2.0 , Headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x USB 3.1 (1 in front)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- UL, VCCI, GS, CB, CCC, FCC, RoHS, KCC, WEEE, CISPR, ICES, MEPS, ERP, CECP, EMI, low halogen
- Power adapter
- Voltage Required
- Power Provided
- 45 Watt
Operating System / Software
- OS Provided
- Windows 10 IoT Enterprise for Thin Clients 64-bit Edition English
- OS Certified
- HP ThinPro, Microsoft Windows Embedded Standard 7E, HP Smart Zero Core, Windows 10 IoT Enterprise
- ENERGY STAR Certified
- 3.5 cm
- 20 cm
- 20 cm
- 962.8 g
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
Warranties (4)
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only | In Stock | £25.29 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years | In Stock | £49.36 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment | In Stock | £37.31 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year | In Stock | £18.06 |
Monitors (2)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £144.44 |
Other bundles (1)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
