HP t520 Flexible Thin Client AMD GX-212JC 4GB 16GB Windows Embedded 8 Standard x64
Quicklinx: BCZ9WS00 Mfr#: G9F14AA#ABU
  • IEEE 802.11n
Get a flexible, reliable desktop experience for your virtual network and knowledge base users with the HP t520 Flexible Thin Client.
  • Essential business performance
    Get the best bang for your investment buck with AMD GX-212JC SOC (System on Chip), HD graphics, and expansive memory and storage.
  • Place it where you need it
    Make the most of your available workspace and deploy the sleek, new, fanless chassis horizontally or vertically in a range of compact settings.
  • Keep it simple
    Make it easy to deploy, manage, and maintain your install base with HP Device Manager, a software tool available exclusively for HP Thin Clients.
  • High quality LAN-like data delivery
    Improve network performance and the end-user experience with HP Velocity software.
  • Get the right OS for your environment and budget
    Select a Windows OS for a familiar Windows experience with Enhanced Write Filter security and added multi-touch support, HP ThinPro for full-featured Linux or HP Smart Zero Technology for simple management.
  • No-hassle virtualization
    Connect to your virtualized desktops and applications with support for the latest ISVs and certifications from Citrix, VMware, and Microsoft.
HP Flexible t520 - tower - GX-212JC 1.2 GHz - 4 GB - SSD 16 GB
Thin client - tower
1 x AMD GX-212JC 1.2 GHz (Dual-Core)
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 8 GB (max) - DDR3L SDRAM - non-ECC - PC3-12800
Storage Controller
SATA
Hard Drive
SSD 16 GB - SATA - M.2
Optical Storage
No optical drive
Audio Output
Integrated
GigE, Bluetooth, 802.11a, 802.11b/g/n
OS Provided
Windows Embedded 8 Standard x64 Edition
Software Included
Citrix ICA, Microsoft RDP, HP ThinState Tools, HP Easy Tools, HP Device Manager, VMware Horizon View, Citrix HDX, Microsoft RemoteFX
4.51 cm x 20 cm x 20.01 cm
1.04 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Tower
Processor / Chipset
CPU
AMD GX-212JC
Clock Speed
1.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
4 GB / 8 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
1 (Total) / 0 (empty)
Unbuffered, low-voltage
Configuration Features
1 x 4 GB
Hard Drive
SSD - M.2
1 x 16 GB
Interface Type
SATA
Multi-level cell (MLC)
Storage Controller
1 x SATA - integrated
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA, DisplayPort
Audio Output
Integrated
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
USB
Mouse
Optical
USB
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Wake on LAN (WoL), PXE support
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Slots
1 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x M.2 Card , 1 (total) / 0 (free) x PCIe Half Mini Card
2 x USB 3.0 (2 in front) , 4 x USB 2.0 , 2 x DisplayPort , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out/headphones - mini-jack (1 in front) , 1 x audio line-in/microphone - mini-jack (1 in front)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
TUV GS, VCCI, UL 1950, EN55022 Class B, FCC, RoHS, AES-128, low halogen
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
Software
Sustainability Information
ENERGY STAR Certified
4.51 cm
20 cm
20.01 cm
1.04 kg
10 °C
10 - 90% (non-condensing)
Sound Emission
12.9 dBA
