HP T430 Celeron N400 4GB Thin Client
Quicklinx: DZTCWS00 Mfr#: 3VL60AT#ABU
Processor Type: Celeron
Operating System: HP ThinPro
Installed Memory: 4GB
Hard Drive Capacity: 16GB
Storage Type: Flash
  • Celeron
Hurry, only 1 left in stock!
£187.42 ex VAT
£224.90 inc VAT
Optimized for desktop virtualization and cloud-based applications, the intuitive HP t430 Thin Client is easy for end users to understand and simple for IT administrators to maintain.
  • Refined from the inside out
    Everything from the user interface to the compact design and processing power delivers a modern computing experience.
  • Better connected
    Although small in size, the HP t430 Thin Client is full of possibilities with USB-C for power and transfer of audio and data, a variety of video outputs, and Ethernet and Wi-Fi connections.
  • Administration made easy
    Simplify the complexity of setting up a virtual desktop or cloud device with a thin client pre-configured with your choice of the Linux -based HP ThinPro or Windows 10 IoT Enterprise operating system and HP manageability software.
HP t430 - DTS - Celeron N4000 1.1 GHz - 4 GB - flash 16 GB
Thin client - desktop slimline
1 x Intel Celeron N4000 / 1.1 GHz (2.6 GHz) (Dual-Core)
Cache Memory
4 MB
Cache Per Processor
4 MB
RAM
4 GB DDR4 SDRAM
Hard Drive
Flash 16 GB - eMMC
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 600
GigE, 802.11ac, Bluetooth 4.2
OS Provided
HP ThinPro
13.5 cm x 13.5 cm x 3.2 cm
410 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Desktop slimline
Processor / Chipset
CPU
Max Turbo Speed
2.6 GHz
Number of Cores
Dual-Core
CPU Qty
1
Cache Memory
Installed Size
4 MB
Cache Per Processor
4 MB
RAM
Installed Size
4 GB
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Configuration Features
1 x 4 GB
Hard Drive
Flash - eMMC
1 x 16 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Interface (Bus) Type
M.2 Card
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9260
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac, Bluetooth 4.2
1 x DisplayPort/USB-C 3.1 Gen 1 , USB 2.0 , 1 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone , 2 x USB 3.1 Gen 1
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
Power adapter
Nominal Voltage
Power Provided
45 Watt
Operating System / Software
OS Provided
HP ThinPro
ENERGY STAR Certified
13.5 cm
13.5 cm
3.2 cm
410 g
Shipping Weight
1.27 kg
Storage Type: Flash
Processor Model: N4000
Type: Thin client
Case Style: Small form factor
Optical Storage: None
Brand: HP
Price Range Ex VAT: 150 - 300
