HP t420 Thin client 2GB RAM 8GB
CLEARANCE!
Clearance
Quicklinx: CH4JWS00 Mfr#: M5R73AT#ABU
Do more with the HP t420 Thin Client, an affordable cloud computing solution that delivers trustworthy reliability and easy deployment and use.
More Bang For Your Buck
Get your choice of essential operating systems, support for VoIP with Microsoft Lync Unified Communications tools, and value-added integrated software from HP that helps you deploy, manage, and optimize your new systems.
Solid Reliability
Plan ahead with reliable flash memory storage and a fan-less design for ultra-quiet deployments. Choose a Global Series model and custom image to help ensure worldwide consistency. Rest easy with a two-year lifecycle and three-year limited warranty.
Place It Where You Need It
Install throughout your business-the modern 0.88 liter form factor complements and fits into a range of compact work spaces, and the integrated VESA mount enables mounting on a flat surface, or directly behind an HP ProDisplay.
Easy Customization
Tailor your installation with the OS of your choice-HP Thin Pro, HP Smart Zero, or Windows Embedded Standard 7E. Enjoy simplified setup, deployment, and maintenance with HP Device Manager, a software tool available exclusively for HP Thin Clients.
  • Create an all-in-one workspace
    Simplify your HP Thin Client Windows Embedded user experience with HP Easy Shell's customized interface and protection for targeted cloud control.
  • Quick connectivity
    Pick the network connection technology that's best for you with Gigabit Ethernet and support for 802.11n Wi-Fi.
  • Designed with the environment in mind
    Reduce power consumption and help lower your costs with an energy-efficient design.
  • Connect and collaborate
    Enjoy your everyday Microsoft Lync productivity tools.
  • Keyboard and mouse included
    Get right to work with the business-class USB keyboard and mouse.
  • Pick your OS
    Select HP ThinPro for full-featured Linux or HP Smart Zero Technology for simple management.
HP t420 - compact desktop - GX-209JA 1 GHz - 2 GB - flash 8 GB - UK
Thin client - compact desktop - rubber feet
1 x AMD GX-209JA 1 GHz (Dual-Core)
RAM
2 GB (installed) / 2 GB (max) - DDR3L SDRAM
Hard Drive
Flash 8 GB
Optical Storage
No optical drive
GigE
Keyboard
OS Provided
HP ThinPro 32-bit
18 cm x 14 cm x 3.5 cm
740 g
Pricing Type
Promo
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Compact desktop
Processor / Chipset
CPU
AMD GX-209JA
Clock Speed
1 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
RAM
Installed Size
2 GB / 2 GB (max)
DDR3L SDRAM
Effective Memory Speed
1066 MHz
Low-voltage
Configuration Features
Provided memory is soldered
Hard Drive
Flash
1 x 8 GB
Multi-level cell (MLC)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA, DVI
Max Monitors Supported
2
Input Device
Keyboard
Keyboard
USB
Localization & Layout
Wake on LAN (WoL), DHCP support, PXE support
4 x USB 2.0 (2 front, 2 rear) , 1 x DVI-D , 1 x VGA , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet)
Rubber feet
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
Pricing Type
Promo
Power adapter
Power Provided
45 Watt
Operating System / Software
OS Provided
HP ThinPro 32-bit English
Sustainability Information
ENERGY STAR Certified
18 cm
14 cm
3.5 cm
740 g
