Do more with the HP t420 Thin Client, an affordable cloud computing solution that delivers trustworthy reliability and easy deployment and use.
More bang for your buck
Get your choice of essential operating systems, support for VoIP with Microsoft Lync Unified Communications tools, and value-added integrated software from HP that helps you deploy, manage, and optimize your new systems. -
Solid reliability
Plan ahead with reliable flash memory storage and a fan-less design for ultra-quiet deployments. Choose a Global Series model and custom image to help ensure worldwide consistency. Rest easy with a two-year lifecycle and three-year limited warranty. -
Place it where you need it
Install throughout your business-the modern 0.88 liter form factor complements and fits into a range of compact work spaces, and the integrated VESA mount enables mounting on a flat surface, or directly behind an HP ProDisplay. -
Easy customization
Tailor your installation with the OS of your choice-HP Thin Pro, HP Smart Zero, or Windows Embedded Standard 7E. Enjoy simplified setup, deployment, and maintenance with HP Device Manager, a software tool available exclusively for HP Thin Clients.
- HP t420 - compact desktop - GX-209JA 1 GHz - 2 GB - flash 16 GB
- Thin client - compact desktop - rubber feet
- Localisation
- Processor
- 1 x AMD GX-209JA 1 GHz (Dual-Core)
- RAM
- 2 GB (installed) / 2 GB (max) - DDR3L SDRAM
- Hard Drive
- Flash 16 GB
- Optical Storage
- No optical drive
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows Embedded Standard 7E 32-bit
- 18 cm x 14 cm x 3.5 cm
- 740 g
- Thin client
- Product Form Factor
- Compact desktop
- Localisation
Processor / Chipset
- CPU
- AMD GX-209JA
- Clock Speed
- 1 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
RAM
- Installed Size
- 2 GB / 2 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1066 MHz
- Low-voltage
- Configuration Features
- Provided memory is soldered
Hard Drive
- Flash
- Capacity
- 1 x 16 GB
- Multi-level cell (MLC)
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Interfaces
- VGA, DVI
- Max Monitors Supported
- 2
- Data Link Protocol
- Wake on LAN (WoL), DHCP support, PXE support
- 4 x USB 2.0 (2 front, 2 rear) , 1 x DVI-D , 1 x VGA , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet)
- Rubber feet
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- Power adapter
- Voltage Required
- Power Provided
- 45 Watt
Operating System / Software
- OS Provided
- Microsoft Windows Embedded Standard 7E 32-bit English
- 18 cm
- 14 cm
- 3.5 cm
- 740 g
