Our thinnest LCD display yet has a sleek design that's easy on the eyes. And the crisp, vibrant view from almost any angle comes at an ultra-affordable price.
Pushing the limits of thin in an eye-catching design. With our innovative use of high-strength, lightweight metal, we've created our thinnest LCD display yet.
Stunning from edge-to-edge
With ultra-wide viewing angles and vivid 1920 x 1080 resolution, this edge-to-edge display delivers an expansive entertainment experience for seamless multiple display setups.
True-to-life color
When the colors on your display are indistinguishable from real life, the result is a beautifully vivid picture. With Technicolor Color Certification, color accuracy is assured every time.
Pushing the limits of thin in an eye-catching design. With our innovative use of high-strength, lightweight metal, we've created our thinnest LCD display yet. -
With ultra-wide viewing angles and vivid 1920 x 1080 resolution, this edge-to-edge display delivers an expansive entertainment experience for seamless multiple display setups. -
True-to-life color
- HP 24er - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class A
- Energy Consumption per Year
- 28 kWh
- Power Consumption (On mode)
- 19 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 7 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Natural silver, blizzard white
- 53.98 cm x 18.35 cm x 40.88 cm
- 3.04 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- CSA, VCCI, C-Tick, BSMI, ISO 9241, NOM, SABS, SASO, CB, CCC, PSB, CSA NRTL/C, FCC, IEC 60950-1, KCC, Energy-using Products (EuP) Lot 6, ICES, S Mark, MEPS, TUV Bauart, E-Standby, KC, CEL, EAC, ISC, GEMS, Energy-using Products (EuP) Lot 5, IS 1121
- 1-year warranty
- Display Type
- Energy Class
- Class A
- 28 kWh
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 60 Hz
- Horizontal Refresh Rate
- 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Anti-glare, On-screen Digital Controls, Technicolour Colour certified, Mercury free, arsenic-free glass
- 53.98 cm x 18.35 cm x 40.88 cm - with stand
- 3.04 kg
- VGA , HDMI (HDCP)
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- Cables Included
- 1 x HDMI cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 19 W
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by
- 0.2 Watt
- 0.12 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- Without stand - width: 53.98 cm - depth: 3.57 cm - height: 32.29 cm - weight: 2.65 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 20 - 80%
