VMware's new best friend. Tailor made for VMware environments, the HP t310 Zero Client delivers amazing processing power with the latest PCoIP technology. Gain a seamless desktop experience, even with extensive multimedia. Reduce costs and free up desk space, while increasing security. With no moving parts, reliability is part of its DNA. Get to work fast with impressive boot and response times.
The perfect fit
Get a fanless design and quiet thermals that support mass installments in small spaces plus a 23-inch diagonal screen that puts all your work front and center. -
The whole package
Be ready to go out of the box with an included keyboard and mouse. -
Make it yours
Customize your all-in-one with an array of inputs that support external peripherals, a second display, Ethernet, and audiovisual interactivity. -
Technology designed for VMware
Accelerate your hardware performance with Tera 2 PCoIP and the Teradici Tera 2321 processor. -
Virtually risk-free
Help protect your data and software by leaving it on the server, and your device with an optional HP Cable Lock. -
One world
Deploy the same configuration around the world with a Global Series SKU that ensures the same product everywhere you do business.
- HP t310 - DTS Tera2321 - 512 MB - flash 256 MB
- Zero client - desktop slimline - PC over IP (PCoIP) technology
- Localisation
- Processor
- 1 x Teradici Tera2321
- RAM
- 512 MB DDR3 SDRAM
- Hard Drive
- Flash 256 MB
- Optical Storage
- No optical drive
- Audio Output
- Stereo - integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- HP Smart Zero Client Service
- 15.2 cm x 13.31 cm x 4.7 cm
- 630 g
- Limited warranty - 3 years
- Zero client
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Desktop slimline
- Localisation
Processor / Chipset
- CPU
- Teradici Tera2321
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
RAM
- Installed Size
- 512 MB
- Technology
- DDR3 SDRAM
Hard Drive
- Flash
- Capacity
- 256 MB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Video Interfaces
- DVI
- Max Monitors Supported
- 2
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 96 kHz
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Technology
- Optical
- Interface
- USB
- Integrated
- Data Link Protocol
- Wake on LAN (WoL), DHCP support
- 4 x USB 2.0 (2 front, 2 rear) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DVI-D , 1 x DVI-I , 1 x audio line-out
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VCCI, EN 61000-3-2, EN55022, ICES-003, ZH1 618, EN 61000-3-3, EN55024, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07
- Power adapter
- Voltage Required
- Power Provided
- 36 Watt
Operating System / Software
- OS Provided
- 15.2 cm
- 13.31 cm
- 4.7 cm
- 630 g
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
