Create a compact, efficient footprint and maximize available space with the HP VESA Mount Bracket for HP t310 Zero Client, which allows you to mount your HP t310 Thin Client behind a display or insert into an HP Integrated Work Center Stand.
- HP thin client to monitor mounting bracket
- Product Type
- Thin client to monitor mounting bracket
- VESA interface support
- Designed For
- Zero Client t310
- Product Type
- Limited warranty - 1 year
- Designed For
- HP Zero Client t310
