HP Stream Pro 11 EE Celeron N3450 4GB 64GB 11.6" Windows 10 S
Quicklinx: DKW5WS00 Mfr#: 3DN40EA#ABU
Display Size: 11.6in
Processor Model: N3450
Operating System: Windows 10 in S mode
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 64GB
  • Celeron
  • IEEE 802.11n
11 in stock
£246.03 ex VAT
£295.23 inc VAT
Engage your students and keep them connected to applications, curriculum, educators, and each other, wherever they work best, with the sturdy Windows-based HP Stream 11 Pro Education Edition.
  • Stay on task in class and on the cloud
    Enable students to access assignments and projects online with Microsoft Office 365 and OneDrive storage, or easily swap to local files and Windows applications with an SSD up to 128 GB and SD card slot for additional storage.
  • Connect and collaborate
    Bring new life to collaborative classwork and studying with an 29.46 cm (11.6") diagonal HD screen, VGA webcam for lifelike video calls, and stereo sound for crystal clear audio. Integrated 2x2 802.11ac wireless helps ensure connectivity in large spaces.
  • Built to go beyond the classroom
    Explore and learn in class and on the go with a durable, lightweight device that's just 18.0mm thin and starts at <1.3kg. It passes MIL-STD 810G testing and is ready for daily bumps and dings with co-molded rubber edges.
HP Stream Pro 11 G4 - Education Edition - 11.6" - Celeron N3450 - 4 GB RAM - 64 GB SSD - UK
Notebook
Operating System
Windows 10 in S mode - English
Intel Celeron N3450 / 1.1 GHz (2.2 GHz) / 2 MB Cache
4 GB DDR3L (provided memory is soldered)
Storage
64 GB - eMMC SSD
Optical Drive
No optical drive
Display
11.6" WLED 1366 x 768 / HD
Graphics
Intel HD Graphics 500
Input Device
ClickPad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
2-cell - up to 11 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip
Smoke grey
30 cm x 20.81 cm x 1.8 cm
1.29 kg
Limited warranty - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
2.2 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz - 1600 MHz
Storage
Main Storage
64 GB SSD - (eMMC)
Display
11.6"
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
HD standard-viewing angle (SVA) eDP anti-glare, 45% sRGB
Audio & Video
Graphics Processor
Camera
Yes - VGA
Video Resolutions
640 x 480
Frame Rate
24 frames per second
Camera Features
Noise reduction
Sound
Stereo speakers, microphone
DTS Studio Sound
Input
Keyboard, ClickPad
Keyboard Layout
Multi-touch clickpad, gesture function
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265 - M.2 Card
Dual stream (2x2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
2-cell lithium polymer
37.69 Wh
Run Time
Up to 11 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
USB 3.1 Gen 1 , USB 2.0 , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
HP Support Assistant, HP ePrint, HP School Pack, HP JumpStart, HP JetAdvantage
Smoke grey
Security
Theft/Intrusion Protection
Security Slot Type
Kensington mini security slot
Power adapter
Low halogen
Localization
1.29 kg
Software applications
HP Stream Pro 11 EE Celeron N3450 4GB 64GB 11.6 Bundle deal on HP Stream Pro 11 EE Celeron N3450 4GB 64GB 11.6" Windows 10 S
£432.49
saving £8.33
£345.79
Optical Storage: None
Graphics: Intel HD Graphics 500
Hard Drive Type: SSD
Touchscreen: Yes
Type: Laptop
Brand: HP
Price Range Ex VAT: 150 - 300
