HP Spectre Pro X360 Intel Core i5-6200U 8GB 128GB 13.3" Windows 10 Pro
Quicklinx: C4SXWS00 Mfr#: V1B02EA#ABU
  • Core i5
  • IEEE 802.11n
The sleek, precision-crafted HP Spectre Pro x360 offers the benefits of flexible 360 degree hinge movement and four operating modes. Stay productive with long battery life on an x360 business convertible with 6th Gen Intel Core i5/i7 processors and optional vPro.
Break from the conventional with 360o flexibility.
Sturdy lightweight aluminum creates a seamless look on this incredibly thin (.61 in. / 15.4 mm.) convertible PC. Starting at just 3.2lbs / 1.45kg, easily switch between four different user modes on the 33,8 cm (13.3") diagonal touch FHD or QHD touchscreen.
Power for hours
Never slow down with long battery life that allows you to create, stay productive, and entertain without having to recharge.
Premium performance
Take charge of your workday with Windows 10 Pro and powerful 6th Gen Intel® Core™ processors with optional vPro™ technology.
Field ready
Never fear bumps and minor spills. The thin and light HP Spectre Pro x360 is designed to undergo MIL-STD 810G testing.
  • Let nothing stand in your way
    The best features of your favorite Windows OS and new features come together in Windows 10 Pro.
  • Take HD up a notch
    Lifelike Full HD with an optional QHD ultra-resolution 33,8 cm (13.3") touch diagonal display.
  • Flexible productivity
    Get through your busy day using a notebook and simply fold the 33,8 cm (13.3") diagonal screen over to go between tablet, stand or tent mode and stay connected on the go.
  • Help secure critical data
    Encrypt your SED or SSD drive with Windows BitLocker and TPM 2.0.
  • Road ready
    Work in more places with multiple connectivity options to help you stay connected on-the-go.
HP Spectre Pro x360 G2 - 13.3" - Intel Core i5 - 6200U - 8 GB RAM - 128 GB SSD - UK
Ultrabook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
128 GB SSD
Display
13.3" WLED touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
32.5 cm x 21.8 cm x 1.54 cm
1.48 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - 1 year , Limited warranty - battery - 1 year
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1600 MHz
Storage
Main Storage
128 GB SSD M.2 SATA 6Gb/s
Display
13.3"
LCD Backlight Technology
WLED backlight
Touchscreen
Yes (multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
350 cd/m²
Full HD ultra wide-viewing angle (UWVA) BrightView eDP
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Camera Features
HP TrueVision FHD
Sound
Stereo speakers, stereo microphone
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell Lithium Ion
56 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Interfaces Details
3 x USB 3.0 , Mini DisplayPort , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, CyberLink Youcam, Adobe Shockwave Player, HP ePrint, Absolute Data Protect, Foxit PhantomPDF Express, Intel Wireless Display, HP Wireless Hotspot, HP Touchpoint Manager, MS BitLocker, CyberLink Power Media Player 12
Case Material
Aluminum
Security
Intel Anti-Theft Technology (iAT)
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC
Localization
1.48 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
