With four operating modes and a long battery life, being productive on the go has never been easier thanks to the HP Spectre Pro X360.
With a touchscreen, as well as the ability to use it as a notebook, tablet, in stand or tent mode, you can make this Spectre laptop work for you.
Powered by an Intel Core i7 processor, the HP Spectre laptop comes with 8GB memory and speedy 256GB solid state drive so you don’t have to compromise on performance even when working on large files.
Connect instantly to the internet wherever you are with the 802.11ac wireless technology and transfer data quickly and efficiently using Bluetooth 4.2.
Looking for enhanced security to keep confidential data secure? With the HP Spectre, you’ll benefit from the Trusted Platform Module security chip and Intel Anti-Theft Technology (iAT).
Transporting your laptop from A to B is easy on account of it weighing just 1.48kg. Measuring 32.5cm x 21.8cm x 1.54cm, it’s ultra-thin to fit easily into your bag when you’re on the go.
Let nothing stand in your way
The best features of your favorite Windows OS and new features come together in Windows 10 Pro. -
Take HD up a notch
Lifelike Full HD with an optional QHD ultra-resolution 33,8 cm (13.3") touch diagonal display. -
Flexible productivity
Get through your busy day using a notebook and simply fold the 33,8 cm (13.3") diagonal screen over to go between tablet, stand or tent mode and stay connected on the go. -
Help secure critical data
Encrypt your SED or SSD drive with Windows BitLocker and TPM 2.0. -
Road ready
Work in more places with multiple connectivity options to help you stay connected on-the-go.
- HP Spectre Pro x360 G2 - 13.3" - Intel Core i7 - 6600U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Ultrabook - flip design
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (6th Gen) - 6600U / 2.6 GHz, up to 3.4 GHz / 4 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 13.3" WLED touchscreen 2560 x 1440 / WQHD
- Graphics
- Intel HD Graphics 520
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 3-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- 32.5 cm x 21.8 cm x 1.54 cm
- 1.48 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 1 year , Limited warranty - battery - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6600U / 2.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 256 GB SSD M.2 SATA 6Gb/s
Display
- 13.3"
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 2560 x 1440 (WQHD)
- Widescreen
- Image Brightness
- 340 cd/m²
- Panel Self Refresh (PSR), QHD ultra wide-viewing angle (UWVA) BrightView eDP
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Camera Features
- HP TrueVision FHD
- Sound
- Stereo speakers, two microphones
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell Lithium Ion
- Capacity
- 56 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- 3 x USB 3.0 , Mini DisplayPort , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, CyberLink Youcam, Adobe Shockwave Player, HP ePrint, Absolute Data Protect, Foxit PhantomPDF Express, Intel Wireless Display, HP Wireless Hotspot, HP Touchpoint Manager, MS BitLocker, CyberLink Power Media Player 12
- Case Material
- Aluminum
- Security
- Intel Anti-Theft Technology (iAT)
- Included Accessories
- Power adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC
- Localization
- 1.48 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
