HP Spectre Pro x360 G2 Intel Core i7-6600U 8GB 256GB Windows 10 Professional (64-bit)
Last Few Remaining
Bundles
Quicklinx: C0QQWS00 Mfr#: V1B00EA#ABU
  • Core i7
  • IEEE 802.11n
With four operating modes and a long battery life, being productive on the go has never been easier thanks to the HP Spectre Pro X360.
With a touchscreen, as well as the ability to use it as a notebook, tablet, in stand or tent mode, you can make this Spectre laptop work for you.
Powered by an Intel Core i7 processor, the HP Spectre laptop comes with 8GB memory and speedy 256GB solid state drive so you don’t have to compromise on performance even when working on large files.
Connect instantly to the internet wherever you are with the 802.11ac wireless technology and transfer data quickly and efficiently using Bluetooth 4.2.
Looking for enhanced security to keep confidential data secure? With the HP Spectre, you’ll benefit from the Trusted Platform Module security chip and Intel Anti-Theft Technology (iAT).
Transporting your laptop from A to B is easy on account of it weighing just 1.48kg. Measuring 32.5cm x 21.8cm x 1.54cm, it’s ultra-thin to fit easily into your bag when you’re on the go.
  • Let nothing stand in your way
    The best features of your favorite Windows OS and new features come together in Windows 10 Pro.
  • Take HD up a notch
    Lifelike Full HD with an optional QHD ultra-resolution 33,8 cm (13.3") touch diagonal display.
  • Flexible productivity
    Get through your busy day using a notebook and simply fold the 33,8 cm (13.3") diagonal screen over to go between tablet, stand or tent mode and stay connected on the go.
  • Help secure critical data
    Encrypt your SED or SSD drive with Windows BitLocker and TPM 2.0.
  • Road ready
    Work in more places with multiple connectivity options to help you stay connected on-the-go.
HP Spectre Pro x360 G2 - 13.3" - Intel Core i7 - 6600U - 8 GB RAM - 256 GB SSD - UK
Ultrabook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (6th Gen) - 6600U / 2.6 GHz, up to 3.4 GHz / 4 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Display
13.3" WLED touchscreen 2560 x 1440 / WQHD
Graphics
Intel HD Graphics 520
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
32.5 cm x 21.8 cm x 1.54 cm
1.48 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - 1 year , Limited warranty - battery - 1 year
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (6th Gen) 6600U / 2.6 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1600 MHz
Storage
Main Storage
256 GB SSD M.2 SATA 6Gb/s
Display
13.3"
LCD Backlight Technology
WLED backlight
Touchscreen
Yes (multi-touch)
Resolution
2560 x 1440 (WQHD)
Widescreen
Image Brightness
340 cd/m²
Panel Self Refresh (PSR), QHD ultra wide-viewing angle (UWVA) BrightView eDP
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Camera Features
HP TrueVision FHD
Sound
Stereo speakers, two microphones
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell Lithium Ion
56 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Interfaces Details
3 x USB 3.0 , Mini DisplayPort , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, CyberLink Youcam, Adobe Shockwave Player, HP ePrint, Absolute Data Protect, Foxit PhantomPDF Express, Intel Wireless Display, HP Wireless Hotspot, HP Touchpoint Manager, MS BitLocker, CyberLink Power Media Player 12
Case Material
Aluminum
Security
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC
Localization
1.48 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
