HP Spectre Pro x360 G2 Intel Core i5-6200U 8GB 256GB SSD 13.3" Windows 10 Professional (64-bit)
Quicklinx: C4SYWS00 Mfr#: V1B05EA#ABU
  • Core i5
  • IEEE 802.11n
The sleek, precision-crafted HP Spectre Pro x360 offers the benefits of flexible 360 degree hinge movement and four operating modes. Stay productive with long battery life on an x360 business convertible with 6th Gen Intel Core i5/i7 processors and optional vPro .
- Windows 10 Pro 64
- Intel® Core™ i5-6200U processor
- 33.8 cm (13.3") diagonal Quad-HD touch screen (2560 x 1440)
- 8 GB RAM and 256 GB SATA SSD
Break from the conventional with 360 degree flexibility
Sturdy lightweight aluminum creates a seamless look on this incredibly thin (.61 in. / 15.4 mm.) convertible PC. Starting at just 3.2lbs / 1.45kg, easily switch between four different user modes on the 33.8 cm (13.3") diagonal touch FHD or QHD touchscreen.
Power for hours
Never slow down with long battery life that allows you to create, stay productive, and entertain without having to recharge.
Premium performance
Take charge of your workday with Windows 10 Pro and powerful 6th Gen Intel® Core™ processors with optional vPro™ technology.
Field ready
Never fear bumps and minor spills. The thin and light HP Spectre Pro x360 is designed to undergo MIL-STD 810G testing.
Featuring
Let nothing stand in your way
The best features of your favorite Windows OS and new features come together in Windows 10 Pro.
Take HD up a notch
Lifelike Full HD with an optional QHD ultra-resolution 33,8 cm (13.3") touch diagonal display.
Flexible productivity
Get through your busy day using a notebook and simply fold the 33.8 cm (13.3") diagonal screen over to go between tablet, stand or tent mode and stay connected on the go.
Help secure critical data
Encrypt your SED or SSD drive with Windows BitLocker and TPM 2.0.
Cloud-based IT management made simple
Manage data, security, and devices from a single cloud-based solution with HP Touchpoint Manager.
Road ready
Work in more places with multiple connectivity options to help you stay connected on-the-go.
One smart pen
Help improve productivity with the optional HP Executive Tablet Pen.
  • Break from the conventional with 360o flexibility
    Sturdy lightweight aluminum creates a seamless look on this incredibly thin (.61 in. / 15.4 mm.) convertible PC. Starting at just 3.2lbs / 1.45kg, easily switch between four different user modes on the 33,8 cm (13.3") diagonal touch FHD or QHD touchscreen.
  • Power for hours
  • Premium performance
    Take charge of your workday with Windows 10 Pro and powerful 6th Gen Intel Core processors with optional vPro technology.
  • Field ready
HP Spectre Pro x360 G2 - 13.3" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD - UK
Ultrabook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Display
13.3" WLED touchscreen 2560 x 1440 / WQHD
Graphics
Intel HD Graphics 520
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
32.5 cm x 21.8 cm x 1.54 cm
1.44 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - 1 year , Limited warranty - battery - 1 year
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Enhanced SpeedStep technology, Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1600 MHz
Storage
Main Storage
256 GB SSD M.2 SATA 6Gb/s
Display
13.3"
LCD Backlight Technology
WLED backlight
Touchscreen
Yes (multi-touch)
Resolution
2560 x 1440 (WQHD)
Widescreen
Panel Self Refresh (PSR), QHD ultra wide-viewing angle (UWVA) BrightView eDP
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Camera Features
HP TrueVision FHD
Sound
Stereo speakers, stereo microphone
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell Lithium Ion
56 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Interfaces Details
3 x USB 3.0 , Mini DisplayPort , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, CyberLink Youcam, Adobe Shockwave Player, HP ePrint, Absolute Data Protect, Foxit PhantomPDF Express, Intel Wireless Display, HP Wireless Hotspot, HP Touchpoint Manager, MS BitLocker, CyberLink Power Media Player 12
Security
Intel Anti-Theft Technology (iAT)
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC
Localization
1.44 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
