HP Spectre Pro 13 i7-6500U 8GB 512GB SSD Bundle
Quicklinx: CFRYWS00 Mfr#: X2F00EA#OPG99011369
World-class design combines with rich features to revolutionize computing. The incredibly thin HP Spectre Pro 13 delivers the power and performance you need for your workday with an irresistible style all its own.
  • Windows 10 Pro 64
  • Intel® Core™ i7-6500U processor
  • 33.8 cm (13.3") diagonal FHD UWVA eDP + PSR WLED BrightView ultra-slim flat (1920 x 1080)
  • 8 GB RAM & lightning-fast next generation 512 GB SSD PCIe storage
  • Includes 3 year Next Business Day Onsite Warranty
A flair for the dramatic
Work in luxury using this incredibly thin and light laptop that suits your sophisticated style with its remarkable internal piston hinge design and hyperbaric cooling system that streamlines the profile of the HP Spectre Pro 13.
No compromise performer
Get the substance and style you crave. This elegant PC uses powerful Intel® Core™ i5/i71 processors, has robust PCIe storage options, and USB-C™ ports for easy connections.
Delight your senses
Treat yourself to a more refined collaboration experience with an FHD IPS Corning® Gorilla® Glass display, exquisite Audio by Bang & Olufsen, and a premium backlit full size keyboard that looks as good as it feels.
Key Features
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, collaboration-ready HP Spectre Pro 13.
Performance to get the job done
Work, surf, and connect with colleagues with the performance of a 6th Gen Intel® Core™ i5/i7 processor, PCIe SSDs, and long battery life that lets you work for hours.
Dramatic design
Delight your senses with the alluring HP Spectre Pro 13. Refined dark ash and copper color surfaces surround the full-sized backlit keyboard. A smooth glass clickpad provides ample space for gestures and precision navigation.
Easy connections
Quickly connect to your tablet, phone, or fitness tracker. The three USB-C™ charging ports allow for hassle-free charging of mobile devices and the HDMI adapter allows fast connections to monitors and projectors.
Cut the clutter
Connect quickly using the optional Thunderbolt™ dock with support for dual 4K monitors.
Connect and collaborate in style
Collaborate effectively using Audio by Bang & Olufsen, HP Noise Cancellation, HP Audio Boost, and an HD webcam.
Cloud-based IT management made simple
HP Touchpoint Manager offers customers simple, useful tools and services from a single cloud-based solution for managing data, security, and a wide array of third party devices.
Valuable support at your service
Get hassle-free technical support with Helpdesk by HP Care. Rely on cost-effective expertise that’s available 24x7, covering multiple brands, devices and operating systems.
