One and Only HP's lowest-power all-in-one smart zero client, delivering PC-like performance using a single wire for power and network connectivity. Simplify your desktop with zero management and zero compromise.
All-in-One design
Create a powerful, client virtualization environment with a streamlined all-in-one solution that combines thin client security and management for impressive PC-like performance.The innovative design features an 18.5" diagonal LED monitor for a small desktop footprint. -
Power-over-Ethernet
Experience our lowest powered, all-in-one smart zero client with Type 1 Power-over-Ethernet – designed to operate within a 13-watt power envelope at 200 nits of brightness through Power-over-Ethernet.Benefit from a faster, one-wire set-up. Just plug in your Power-over-Ethernet wire and you're ready. No A/C attach required. -
PC-like Performance
Built using a high performance Texas Instruments TMS320DM8148 ARM?R CortexTM processor with 1 GB DDR3 SDRAM and 2GB eMMC Flash memory capacity.Supports Microsoft , Citrix and VMware VDI implementations in a single "appliance" set-up.Featuring DSP Acceleration for RemoteFX and ARM Neon extensions for Citrix SoC for a more flexible user experience. -
HP Smart Zero Client Technology
Improve network performance and the end-user experience with HP Velocity software.Simplify your IT atmosphere with complete configuration and reconfiguration control over your operating system.Automatic Intelligence, inherited by HP Smart Zero Client Services, establishes a secure desktop environment for all devices in minutes, and downloads everything it needs to deliver a robust user experience.If your client virtualization software changes your HP Smart Client will adapt to your environment. Simply repurpose your HP Smart Client for another protocol, saving time and money. -
Eco-highlights
Help reduce your company's operating costs with HP's first, ultra-low power, Type 1 PoE – Power-over-Ethernet – all-in-one smart zero client solution.The HP t410 All-in-One Smart Zero Client also leads the industry in the development of environmental thin client technologies: ENERGY STAR qualified, EPEAT Gold registered, Low halogen materials. -
Backed by HP
HP Thin Clients are backed by HP global service and support through our network of over 50,000 IT professionals in over 100 countries.The HP t410 All-in-One Smart Zero Client includes a standard, three-year limited hardware warranty in most regions.
- HP Smart t410 - all-in-one - Cortex-A8 1 GHz - 1 GB - flash 2 GB - LED 18.5"
- Zero client - all-in-one - PC over IP (PCoIP) technology
- Localisation
- Processor
- 1 x ARM Cortex-A8 1 GHz
- Cache Memory
- 256 KB L2 Cache
- Cache Per Processor
- 256 KB
- RAM
- 1 GB DDR3 SDRAM
- Hard Drive
- Flash 2 GB
- Optical Storage
- No optical drive
- Monitor
- 18.5" - LED - 1366 x 768 (HD)
- Audio Output
- Stereo - integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- HP Smart Zero Client Service
- Software Included
- VMware View Client, Citrix ICA 12.0, HP Device Manager, Microsoft RDP 7.1
- 44.93 cm x 15.91 cm x 34.1 cm
- 3.65 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years
- Zero client
- Recommended Use
- Small business, corporate business
- Product Form Factor
- All-in-one
- Localisation
Processor / Chipset
- CPU
- ARM Cortex-A8
- Clock Speed
- 1 GHz
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- L2 Cache - 256 KB
- 256 KB
RAM
- Installed Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 400 MHz
Hard Drive
- Flash
- Capacity
- 2 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- LED
- Diagonal Size
- 18.5"
- Native Resolution
- 1366 x 768 (HD)
- Widescreen Display
Graphics Controller
- Integrated
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 96 kHz
Input Device
- Mouse, keyboard
- Integrated
- Data Link Protocol
- Wake on LAN (WoL), DHCP support, PXE support
- 4 x USB 2.0 (2 front, 2 rear) , 1 x microphone , 1 x headphones , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- VESA Mounting Interface
- 100 x 100 mm
- VCCI, EN 61000-3-2, EN55022, ZH1 618, EN 61000-3-3, EN55024, FCC, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07
- Power adapter
- Voltage Required
- Power Provided
- 24 Watt
Operating System / Software
- OS Provided
- Software
- ENERGY STAR Certified
- 44.93 cm
- 15.91 cm
- 34.1 cm
- 3.65 kg
- 10 °C
- 35 °C
- 5 - 95% (non-condensing)
