HP Slim Wireless Keyboard and Mouse
Quicklinx: CKL9WS00 Mfr#: T6L04AA#ABU
Wired / Wireless: Wireless
Compatibility: PC
£28.75 ex VAT
£34.50 inc VAT
Boost productivity and maximize your workspace with the stylish and compact HP Slim Wireless Keyboard and Mouse, designed to complement the 2015 class of HP Business PCs.
Bold redesign
Pair your PC with a sleek, restyled, reduced-size keyboard that packs a familiar notebook-style layout and function keys into a smaller design to give you more room on the desk. The comfortably intuitive, low-profile, quiet keys make data entry easy.
Compatible and flexible
Interact seamlessly with a full keyboard layout and a mouse that's designed for either hand.
Connect wirelessly
Feel free to move around the desk or table with a keyboard and mouse that keep working up to 30 ft (10 m) away from your PC through a single USB dongle that has 2.4 GHz wireless connectivity.
Smart, efficient battery
Work without worry with a keyboard that has up to an 11-month battery life. Avoid surprises with convenient software notifications that warn you when you need to swap out.
Rest easy
Get the reassurance of a one-year limited warranty.
  • Bold redesign
  • Compatible and flexible
  • Connect wirelessly
  • Smart, efficient battery
  • Rest easy
HP Slim - keyboard and mouse set - UK
Keyboard and mouse set
2.4 GHz
Wireless Receiver
USB wireless receiver
Input Device
Keyboard
Wireless
Localization and Layout
Pointing Device
Mouse - wireless
1-year warranty
HP 24X G7, 24X G8, 25X G8, 340 G7; Elite c1030; EliteBook 83X G8, 84X G8, 85X G8; EliteBook x360; Mobile Thin Client mt46; Pro c645; ProBook 430 G8, 44X G8, 45X G8, 630 G8, 635, 640 G8, 650 G8; ProBook x360; ZBook Power G7, Power G8, Studio G8; ZBook Firefly 14 G8, 15 G8; ZBook Fury 15 G7, 15 G8
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 43.6 cm x 13.7 cm x 2.1 cm / 560 g , Mouse: 6.29 cm x 11.5 cm x 3.73 cm / 100 g
Input Device
Keyboard - wireless
Pointing Device
Mouse - wireless
AAA type
Limited warranty - 1 year
HP 240 G8, 245 G6, 245 G7, 245 G8, 246 G7, 250 G7, 250 G8, 255 G7, 255 G8, 340 G5, 340 G7, 340S G7, 348 G5, 470 G7 , HP Chromebook 11 G6, 11 G7, 11 G8, 11A G6, 11A G8, 14 G5, 14 G6, 14A G5 , HP Chromebook Enterprise 14 G6 , HP Chromebook Enterprise x360 14E G1 , HP Chromebook x360 11 G2, 11 G3, 14 G1 , HP Elite c1030 Chromebook, c1030 Chromebook Enterprise , HP Elite Dragonfly , HP EliteBook 1040 G4, 1050 G1, 735 G5, 735 G6, 745 G5, 745 G6, 755 G5, 830 G5, 830 G6, 830 G7, 830 G8, 835 G7, 835 G8, 840 G5, 840 G6, 840 G7, 840 G8, 840r G4, 845 G7, 845 G8, 850 G5, 850 G6, 850 G7, 850 G8, 855 G7, 855 G8 , HP EliteBook x360 1030 G3, 1030 G4, 1030 G7, 1030 G8, 1040 G5, 1040 G6, 1040 G7, 1040 G8, 830 G5, 830 G6, 830 G7, 830 G8 , HP Mobile Thin Client mt22, mt45, mt46 , HP Pro c640 Chromebook, c645 Chromebook, c645 Chromebook Enterprise , HP ProBook 430 G5, 430 G6, 430 G7, 430 G8, 440 G5, 440 G6, 440 G7, 440 G8, 445 G6, 445 G7, 445 G8, 445r G6, 450 G5, 450 G6, 450 G7, 450 G8, 455 G5, 455 G6, 455 G7, 455 G8, 455r G6, 470 G5, 630 G8, 635 Aero G7, 640 G4, 640 G5, 640 G8, 645 G4, 650 G4, 650 G5, 650 G8 , HP ProBook x360 11 G3, 11 G4, 11 G5, 11 G6, 11 G7, 435 G7, 435 G8, 440 G1 , HP Spectre x360 15-ch006tx , HP Stream Pro 11 G4 (Education Edition) , HP ZBook 14u G5 Mobile Workstation, 14u G6 Mobile Workstation, 15 G5 Mobile Workstation, 15 G6 Mobile Workstation, 15u G5 Mobile Workstation, 15u G6 Mobile Workstation, 15v G5 Mobile Workstation, 17 G5 Mobile Workstation, 17 G6 Mobile Workstation, Create G7, Power G7 Mobile Workstation, Power G8 Mobile Workstation, Studio G5 Mobile Workstation, Studio G7 Mobile Workstation, Studio G8 Mobile Workstation, Studio x360 G5 Mobile Workstation , HP ZBook Firefly 14 G7 Mobile Workstation, 14 G8 Mobile Workstation, 15 G7 Mobile Workstation, 15 G8 Mobile Workstation , HP ZBook Fury 15 G7 Mobile Workstation, 15 G8 Mobile Workstation, 17 G7 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
Compatibility: PC
Brand: HP
