HP Slice VESA Plate
HP Slice VESA Plate
Quicklinx: CD8FWS00 Mfr#: X8U74AA
Mount your HP Elite Slice, Cover, and Modules to a fixed location on a desk or table with the HP VESA Plate, which allows them to be stacked and anchored with the 100 x 100 VESA pattern.
Assemble and disassemble the HP VESA Plate from your configuration with the easy Quick Release latch.
Securing your solution is simpler than ever with an integrated universal lock slot that allows you to lock your HP Elite Slice and HP VESA Plate together with one cable lock.
Use the HP VESA Plate with a stacked configuration of an HP Elite Slice and HP Wireless Charging or HP Collaboration Cover, HP Audio Module, and HP ODD Module.
HP Elite Slice and HP Elite Slice for Meeting Rooms
  • Easy on and off
  • Lock it down
  • Mix and match
HP VESA Plate mounting kit
Mounting kit - desk-mountable
16.5 cm x 16.5 cm x 1.65 cm
257 g
Elite Slice, Slice for Meeting Rooms, Slice for Meeting Rooms G2, Slice G2
16.5 cm
16.5 cm
1.65 cm
257 g
AV Furniture
Mounting kit
Placing / Mounting
Desk-mountable
HP Elite Slice, Slice for Meeting Rooms, Slice for Meeting Rooms G2 for Intel Unite, Slice for Meeting Rooms G2 for Skype Room Systems, Slice G2, Slice G2 Audio Ready with Microsoft Teams Rooms, Slice G2 Partner Ready with Microsoft Teams Rooms, Slice G2 with Intel Unite, Slice G2 with Microsoft Teams Rooms
