Product
HP Slice VESA Plate
HP Slice VESA Plate
Quicklinx: CD8FWS00 Mfr#: X8U74AA
Mount your HP Elite Slice, Cover, and Modules to a fixed location on a desk or table with the HP VESA Plate, which allows them to be stacked and anchored with the 100 x 100 VESA pattern.
Assemble and disassemble the HP VESA Plate from your configuration with the easy Quick Release latch.
Securing your solution is simpler than ever with an integrated universal lock slot that allows you to lock your HP Elite Slice and HP VESA Plate together with one cable lock.
Use the HP VESA Plate with a stacked configuration of an HP Elite Slice and HP Wireless Charging or HP Collaboration Cover, HP Audio Module, and HP ODD Module.
HP Elite Slice and HP Elite Slice for Meeting Rooms
  • Easy on and off
  • Lock it down
  • Mix and match
HP VESA Plate - desk mount
Desk mount
16.5 cm x 16.5 cm x 1.65 cm
257 g
Elite Slice, Slice for Meeting Rooms, Slice for Meeting Rooms G2 for Intel Unite
16.5 cm
16.5 cm
1.65 cm
257 g
AV Furniture
Desk mount
HP Elite Slice, Slice for Meeting Rooms, Slice for Meeting Rooms G2 for Intel Unite
