HP Slice ODD Module
Quicklinx: CD8JWS00 Mfr#: X8U73AA
Drive Type: DVD-ROM
Enclosure Type: External
Type: Disk drive
  • DVD-ROM
£80.00 ex VAT
£96.00 inc VAT
Hardware compatibility
HP Elite Slice and HP Elite Slice for Meeting Rooms
Quickly and easily back up files and access content from your choice of optical media with the HP ODD Module that snaps into your HP Elite Slice solution for a simple unified footprint.
No cabling or screws required
Snap the Module beneath your HP Elite Slice with a sturdy USB-type connection that provides a simple and clean solution with no messy cables.
Multi ODD media compatible
Support legacy content on CD or DVDs, or use this module with the HP Audio Module as a beautiful media player.
Lock it down
Securing your solution is simpler than ever with an integrated universal lock slot that allows you to lock your Module and HP Elite Slice together with one cable lock.
Mix and match
Create a unique solution for each of your employees when you use the HP ODD Module stacked with your HP Elite Slice and any of the other HP Elite Slice accessories.
  • No cabling or screws required
  • Multi ODD media compatible
  • Lock it down
  • Mix and match
HP ODD Module - DVD-ROM drive - external
16.5 cm x 16.5 cm x 2.45 cm
452 g
Optical Storage
DVD-ROM
1-year warranty
OMEN X by HP 900; HP 20, 22, 24, 24 g008; Elite Slice, Slice for Meeting Rooms, Slice for Meeting Rooms G2, Slice G2; ENVY 27, 750; ENVY Curved 34; Pavilion 24, 27; Pavilion Wave 600
16.5 cm
16.5 cm
2.45 cm
452 g
Optical Storage
DVD-ROM
Limited warranty - 1 year
OMEN X by HP 900-000t , HP 20-c001la, 20-c001na, 20-c001ni, 20-c005nf, 20-c005ns, 20-c006la, 20-c010, 20-c010nd, 20-c011nf, 20-c011np, 20-c011ns, 20-c012nf, 20-c015na, 20-c015nl, 20-c016nl, 20-c019la, 20-c020, 20-c020nf, 20-c021nf, 20-c021nl, 20-c022, 20-c023w, 20-c024nl, 20-c217la, 22-b000ns, 22-b000ny, 22-b002na, 22-b003la, 22-b005nf, 22-b005np, 22-b009, 22-b009la, 22-b010, 22-b016, 22-b016ns, 22-b017la, 22-b022no, 22-b022nw, 22-b023ns, 22-b024nf, 22-b025nw, 22-B026ns, 22-b030nj, 22-b031na, 22-b031ur, 22-b041ne, 22-b050na, 22-b051nf, 22-b052nb, 22-b065na, 22-b066na, 22-b308la, 24 g008nc, 24-g003ns, 24-g004na, 24-g004ns, 24-g006la, 24-g006na, 24-g008ns, 24-g010, 24-G065ng , HP Elite Slice, Slice for Meeting Rooms, Slice for Meeting Rooms G2 for Intel Unite, Slice for Meeting Rooms G2 for Skype Room Systems, Slice G2 Audio Ready with Microsoft Teams Rooms, Slice G2 Partner Ready with Microsoft Teams Rooms, Slice G2 with Intel Unite, Slice G2 with Microsoft Teams Rooms , HP ENVY 27-b010, 750-411, 750-424, 750-471na, 750-537cb, 750-545xt, 750-555qe, 750-567cb , HP ENVY Curved 34-a001la, 34-a090nb, 34-a090nf, 34-a090nl, 34-a090no, 34-a090nz, 34-a150, 34-b000ng, 34-b004la, 34-b010nl, 34-b013nf, 34-b071ns, 34-b080nl , HP Pavilion 24-b001la, 24-b008la, 24-b010, 24-b017c, 27-a002la, 27-a021, 27-a031 , HP Pavilion Wave 600-a009, 600-a029
Drive Type: DVD-ROM
Type: Disk drive
Brand: HP
