Reimagine the desktop experience with HP’s smallest desktop
The soul of a powerful PC inside a beautiful modular body, HP Elite Slice is like no desktop you’ve ever seen. Designed for the modern workforce, each compact, cable-less module adds functionality to transform Slice into something new.
Beautiful. Powerful. Innovative.
Stunning compact design and amazing engineering – from custom thermal designed air cooling that enables its small size to being powered by a single cable from an optional HP Elite display – HP Elite Slice reinvents what it means to be a desktop PC.
Ingenious versatility
A communication hub for collaboration, a wireless charging station, and a multimedia player. Optional cable-less expansion modules let you transform HP Elite Slice to suit a wide range of users and locations – all with a powerful PC at its core.
Secure, powerful, business performance
This innovative commercial-grade desktop is equipped with Intel® Core™ 35 watt desktop processors, Intel® vPro™ , and Elite-class security including HP Sure Start with Dynamic Protection. HP Elite Slice combines power and beauty.
Starts the call. Works the room.
HP Slice for Meeting Rooms is an integrated conferencing solution designed for the office of the future. Simple, secure, and easily managed, it combines one-touch conferencing with the soul and manageability of a powerful PC.
One touch conferencing
Ditch the frustrations, wasted time, and cable clutter of traditional conference room setups. HP Elite Slice for Meeting Rooms makes collaboration fast and easy with one-touch control of Skype for Business and wireless sharing with Intel Unite . -
Crystal clear sound for you and them
Experience 360° immersive sound on the HP Audio Module with HP Audio Boost, HP Noise Cancellation Software, a dual-microphone array with far-field 5-meter range, and custom-tuned Audio by Bang & Olufsen. -
HP Elite Slice for Meeting Rooms, a stylish centerpiece for modern conference rooms, offers Windows 10 Pro, Intel Core 35W desktop processors, vProTM , and HP Elite-class security and manageability. Complete the solution with an immersive HP display.
- HP Elite Slice for Meeting Rooms - USFF - Core i5 6500T 2.5 GHz - vPro - 8 GB - SSD 256 GB
- Personal computer - ultra small form factor
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- Intel Core i5 (6th Gen) 6500T / 2.5 GHz (, up to 3.1 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - SATA 6Gb/s
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 530
- Audio Output
- Stereo
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Skype, HP Recovery Manager, HP Support Assistant, HP SoftPaq Download Manager (free download), Windows Defender, HP Systems Software Manager (free download), HP Velocity, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Driver Packs, HP CIK for Microsoft SCCM (free download), HP Image Assistant (free download), Windows 10 Welcome App, HP Sure Connect
- Black sparkle, metal copper finish
- 16.5 cm x 16.5 cm x 3.55 cm
- 1.05 kg
- Personal computer
- Product Form Factor
- Ultra small form factor
- Embedded Security
- Trusted Platform Module (TPM 1.2 and TPM 2.0)
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q170
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total)
- Unbuffered
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Bays
- 1 (total) / 0 (free) x internal 2.5"
- Slots
- 1 M.2 Card - 2230 , 1 (total) / 1 (free) x M.2 Card - 2280 , 2 SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU
- 1 x headphones/microphone , 2 x USB-C 3.1 Gen 1 , 2 x USB 3.1 - Type A (one of them with wake functionality, one of them is charging) , 1 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) - RJ-45
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Energy-using Products (EuP) Lot 6, Common Criteria EAL4+, low halogen, Energy-Related Products (ErP) Lot 3, RoHS2 2.06, ACPI 5.08
- Power adapter
- Voltage Required
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- 16.5 cm
- 16.5 cm
- 3.55 cm
- 1.05 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
