HP SINGLE MONITOR ARM
Quicklinx: BYK4WS00 Mfr#: BT861AA
Accessory Type: Bracket
10 in stock
£156.55 ex VAT
£187.86 inc VAT
The HP Single Monitor Arm is the perfect desk accessory for your work life. Sleek and streamlined, the HP Single Monitor Arm is designed to complement the way you work.
HP Single Monitor Arm - mounting kit
Mounting kit
Mounting Components
Desk clamp mount, grommet mount, single-screen mounting arm
Adjustments
Tilt
Recommended Use
LCD display
Recommended Display Size
Up to 24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
9.1 kg
Jack black
HP 100, 6300, Elite 8300, L2105, LA1751, LA1905, LA1951, LA2006, LA22, LA2206, LA2306, LE1711, LE19, LE1901, LE1911, LE2001, t430, ZR22, ZR24; EliteDesk 705 G3, 705 G4; EliteOne 705 G2, 800 G1, 800 G2, 800 G3, 800 G5; ProDesk 400 G3, 600 G4; ProOne 400 G2, 400 G3, 400 G4, 600 G1, 600 G2, 600 G3
Jack black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Up to 24"
Adjustments
Tilt
Max Load Weight
9.1 kg
Adjustable height
Compaq LA2405wg , HP 100B, L2105tm Touchscreen, LA1905wg, LA2205wg, LE1851w, LE1901w, LE1901wm, LE2001w, LE2001wm, LE2201w, LP2065, LP2275w, LP2475w, t430, ZR22w, ZR24w , HP EliteDesk 705 G3, 705 G4 , HP EliteOne 705 G2, 800 G1, 800 G2, 800 G3, 800 G5 , HP ProDesk 400 G3, 600 G4 , HP ProOne 400 G2, 400 G3, 400 G4, 600 G1, 600 G2, 600 G3 , HP Compaq 6300 Pro PC, Elite 8300 PC, L2105tm, LA1751g, LA1905wg, LA1951G, LA2006x, LA2205wg, LA2206x, LA22f, LA2306x, LA2405wg, LE1711, LE1901wl, LE1911, LE19f
HP SINGLE MONITOR ARM Bundle deal on HP SINGLE MONITOR ARM
£255.72
Brand: HP
Price Range Ex VAT: 150 - 300
