HP ScanJet Pro 3500 f1 Document Scanner
Quicklinx: BT5WWS00 Mfr#: L2741A#B19
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 3100 mm
Interface: USB 3.0
Compatibility: Mac, PC
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£312.08 ex VAT
£374.49 inc VAT
Get reliable, high-speed scanning for complex projects – this scanner can handle 3,000 sheets per day. Scan both sides of the page at up to 50 images (25 pages) per minute. HP EveryPage helps avoid misfeeds and simplifies your workflow.
  • Fast, reliable two-sided scanning
    Produce up to 50 images (25 pages) per minute with two-sided scanning. Reliably scan 3,000 sheets per day.Capture every page easily – even for stacks of mixed media – with HP EveryPage and an ultrasonic sensor.Scan documents up to 21.6 x 309.9 cm (8.5 x 122 in) through the ADF, and use the flatbed for bulky media.Spend less time waiting – scans reach their destination at fast speeds with a USB 3.0 connection.
  • Work smarter with quick, simple scanning
    Define scan profiles for common document types and scan to multiple destinations with HP Scan software.Create one-button scan settings for recurring tasks and make selections using the LCD control panel.Quickly share or archive scans directly to popular cloud destinations with HP Scan software.Scan directly into applications without opening another program with HP's full-featured TWAIN driver.
  • Sharp images and accurate text capture
    Accurately capture text from documents for easy editing with HP Scan and I.R.I.S. Readiris Pro OCR software.Get sharp, true-to-life scans of documents, graphics, and photos with up to 1200 dpi resolution.Book-edge scanning prevents distorted text, even near the spine of books and other bound materials.Auto-imaging features in the included HP Scan software let you enhance images and delete blank pages.
HP Scanjet Pro 3500 f1 - document scanner - desktop - USB 3.0
Document scanner - desktop
Interface Type
USB 3.0
Scan Element Type
CMOS / CIS
Light Source
LED
Max Supported Document Size
216 x 3100 mm
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
25 ppm (mono) / 25 ppm (colour)
Max Document Size
216 mm x 3100 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card, labels, photo, envelope
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
3000 scans per day
Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10 (32/64 bits)
Microsoft Certification
Compatible with Windows 7
46 cm x 38.7 cm x 14.5 cm
5.58 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 3.0
216 x 3100 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
1200 dpi x 1200 dpi
Scan Mode
Single-pass
Automatic Duplexing
Scan Element Type
CMOS / CIS
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
25 ppm
Max Document Scan Speed Colour
25 ppm
Control Panel Buttons Functions
Scan, cancel, duplex, tools
Duty Cycle
3000 scans per day
Scanner Speed Details
25 ppm - 300 dpi , 50 ipm - duplex - 300 dpi (front) / 300 dpi (back)
Scanner Features
Built-in LCD screen
TWAIN, WIA
Media Handling
Max Document Size
216 mm x 3100 mm
Supported Document Size Details
ADF - up to 216 x 3100 mm , Flatbed - up to 216 x 297 mm
Automatic
50 sheets
USB 3.0
1 x USB cable
C-Tick, BSMI, CISPR 24, cUL, EN 61000-3-2, EN55022, ICES-003, SASO, EN 61000-3-3, CISPR 22, CCC, EMC, RoHS, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, KCC, BSMI CNS 13438, FCC CFR47 Part 15 B, CSA C22.2 No. 60950-1 Second Edition, KN22, EAC, TER, PVOC, CoC
ENERGY STAR Certified
External power adapter
Power Consumption Stand by
4.51 Watt
Power Consumption Sleep
1.4 Watt
Software Included
Readiris Pro, Cardiris, Nuance PaperPort, HP Scan, HP Scanner Tools Utility
System Requirements Details
Windows 7/8/8.1/10 - 2 GHz - RAM 2 GB - HD 170 MB , MacOS X 10.9/10.10 - RAM 1 GB
46 cm
38.7 cm
14.5 cm
5.58 kg
Shipping Width
57.9 cm
Shipping Depth
49.9 cm
Shipping Height
24.5 cm
Shipping Weight
7.6 kg
Limited warranty - 1 year
10 °C
35 °C
15 - 80% (non-condensing)
Interface: USB 3.0
Compatibility: Mac
Compatibility: PC
Brand: HP
Price Range Ex VAT: 300 - 500
