HP Scanjet Pro 3000 s3 Sheet-feed Scanner - document scanner
Quicklinx: CJ2VWS00 Mfr#: L2753A#B19
Manage projects and workflows quickly and confidently. Easily handle mixed media, and get one-pass duplex scanning with speeds up to 35 ppm/70 ipm. Scan to mobile devices for on-the-go control. Recommended for 3,500 pages per day.
Fast scanning. Superb results. Every page.
Produce scans at up to 35 ppm/70 ipm with two-sided scanning that captures both sides at once.
Optimise workflows with one-touch scanning
Streamline routine work with one-touch scanning – create one-button, custom settings for recurring scan jobs.
Capture business documents like a pro
Define scan profiles for common document types, and scan to multiple destinations with HP Scan software.
  • Fast scanning
    Produce scans at up to 35 ppm/70 ipm with two-sided scanning that captures both sides at once.Capture every page easily – even stacks of mixed media – with HP EveryPage and an ultrasonic sensor.Free up space for work. This HP ScanJet Pro is small and slim – a modern design perfect for the desktop.Handle paper from 40 gsm (11 lb.) to 413 gsm (110 lb.) weight and up to 21.6 x 309.9 cm (8.5 x 122 inches).
  • Optimise workflows with one-touch scanning
    Streamline routine work with one-touch scanning – create one-button, custom settings for recurring scan jobs.Scan images directly into applications with included and full-featured TWAIN and ISIS .Easily transfer scans into editable text, secure PDF files, and more file types, using built-in OCR.Quickly share or archive scans directly to popular cloud destinations with HP Scan software.
  • Capture business documents like a pro
    Define scan profiles for common document types, and scan to multiple destinations with HP Scan software.Scan directly to mobile devices with the HP JetAdvantage Capture App, using the optional wireless accessory, and then edit and save files.Capture and organise documents, business cards, and other file types with feature-rich software.
HP Scanjet Pro 3000 s3 - document scanner - desktop - USB 3.0, USB 2.0
Document scanner - desktop
Interface Type
USB 3.0, USB 2.0
Max Supported Document Size
216 x 3100 mm
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
48-bit colour
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
35 ppm (mono)
Max Document Size
216 mm x 3100 mm
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
3500 scans per day
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 3.0, USB 2.0
216 x 3100 mm
Scanner
Input Type
Colour Depth
48-bit colour
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Max Document Scan Speed B/W
35 ppm
Duty Cycle
3500 scans per day
Scanner Speed Details
35 ppm , 70 ipm
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 3100 mm
Automatic
50 sheets
Interfaces Details
USB 2.0 , USB 3.0
ENERGY STAR Certified
Shipping Width
39.7 cm
Shipping Depth
30.3 cm
Shipping Height
24.8 cm
Shipping Weight
5 kg
