HP Scanjet Pro 2000 s1 Sheet-feed Scanner - document scanner
Quicklinx: CJ2TWS00 Mfr#: L2759A#B19
£223.46 ex VAT
£268.15 inc VAT
Fast, affordable, and designed to handle everything from simple colour jobs to complex workflows. Quickly and reliably digitise larger projects with scan speeds up to 24 ppm/48 ipm and a 50-page ADF. Recommended for 2,000 pages per day.
Small size. Fast scans. Same reliable results.
Produce scans at up to 24 ppm/48 ipm with two-sided scanning that captures both sides at once.
Optimise workflows with one-touch scanning
Streamline routine work with one-touch scanning – create one-button, custom settings for recurring scan jobs.
Capture business documents like a pro
Define scan profiles for common document types, and scan to multiple destinations with HP Scan software.
  • Small size
    Produce scans at up to 24 ppm/48 ipm with two-sided scanning that captures both sides at once.Free up space for work. This HP ScanJet Pro is small and slim – a modern design perfect for the desktop.Don't wait for warm-up – HP Instant-on Scanning lets you begin scanning quickly.Load up to 50 pages into the automatic document feeder for fast, unattended scanning.
  • Optimise workflows with one-touch scanning
    Streamline routine work with one-touch scanning – create one-button, custom settings for recurring scan jobs.Scan images directly into applications with included and full-featured TWAIN and ISIS .Easily transfer scans into editable text, secure PDF files, and more file types, using built-in OCR.Quickly share or archive scans directly to popular cloud destinations with HP Scan software.
  • Capture business documents like a pro
    Define scan profiles for common document types, and scan to multiple destinations with HP Scan software.Capture and organise documents, business cards, and other file types with feature-rich software.Produce clear, legible scans – up to 600-dpi resolution.
HP Scanjet Pro 2000 s1 Sheet-feed - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Max Supported Document Size
216 x 3100 mm
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
48-bit colour
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
24 ppm (mono)
Max Document Size
216 mm x 3100 mm
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
2000 scans per day
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
216 x 3100 mm
Scanner
Input Type
Colour Depth
48-bit colour
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Max Document Scan Speed B/W
24 ppm
Duty Cycle
2000 scans per day
Scanner Speed Details
24 ppm , 48 ipm , 6.9 sec/scan - colour - 10x15cm - 200 dpi , 9.13 sec/scan - A4 - 300 dpi
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 3100 mm
Supported Document Size Details
ADF
Automatic
50 sheets
USB 2.0 - Type B
ENERGY STAR Certified
Shipping Width
39.7 cm
Shipping Depth
24.8 cm
Shipping Height
24.2 cm
Shipping Weight
4 kg
Limited warranty - 1 year
