HP Scanjet Maintenance Kits ensure your HP scanner stays in working condition. This replacement roller and separation pad reduces jams caused by normal wear and extends the life of your scanner. Easy installation gets you back to business quickly.
- HP Scanjet ADF Roller Replacement Kit - maintenance kit
- Product Type
- Maintenance kit
- 28.5 cm x 9 cm x 6 cm
- 190 g
- Designed For
- ScanJet Enterprise Flow N9120 Flatbed Scanner, N9120 Document Flatbed Scanner
- Product Type
- Maintenance kit
- 28.5 cm
- 9 cm
- 6 cm
- 190 g
- Shipping Dimensions (WxDxH) / Weight
- 28.5 cm x 9 cm x 6 cm / 0.2 kg
- Designed For
- HP ScanJet Enterprise Flow N9120 Flatbed Scanner, N9120 Document Flatbed Scanner
