Get superior colour accuracy with innovative 6-colour photo scanning – exclusive to HP. Scan slides and negatives too, capturing every detail with 4800 x 9600-dpi hardware resolution. Restore faded colours and fix old photos and slides.
HP-exclusive 6-colour high-definition photo scanning plus slide and negative adapter
Capture colours that are 40% more accurate than other scanners with HP's exclusive 6-colour, 96-bit scanning. Scan slides and negatives too using the built-in adapter, and get crisp, high definition results at 4800 x 9600-dpi resolution. -
Preserve your memories – intuitive tools help you restore old or damaged originals
Bring old photos, slides and negatives back to life with a range of intuitive tools including easy dust and scratch removal. Restore faded colour, remove red-eye and bring detail out of dark photos, all using HP Real Life technologies. -
Scan via convenient one-touch buttons, and edit and share using included software
Enjoy fast, convenient one-touch photo or slide/negative scanning. Make copies and reprints at the touch of a button too, and save files as PDFs for easy sharing. Organise, edit and email photos with easy-to-use HP Photosmart Software.
- HP ScanJet G4010 Photo Scanner - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Max Supported Document Size
- 216 x 311 mm
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 96-bit colour
- Optical Resolution
- 4800 dpi x 9600 dpi
- Max Document Size
- 216 mm x 311 mm
- Supported Document Type
- Plain paper, slides, bulk objects (such as books, magazines and other bound materials), film
- Document Feeder Type
- Manual
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Media Center Edition 2005, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.3.9, Apple MacOS X 10.4 or later
- Microsoft Certification
- Certified for Windows Vista
- 30.3 cm x 50.8 cm x 9.8 cm
- 4.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 216 x 311 mm
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 96-bit colour
- CCD
- Control Panel Buttons Functions
- Scan, copy, Scan film, Scan-to-PDF
- Scanner Speed Details
- 29 sec/scan - photo - colour - 10x15cm , 25 sec/scan - OCR - A4 , 24 sec/scan - film (positives) - 35mm , 39 sec/scan - film (negatives) - 35mm , 8.5 sec/scan - preview
- Scanner Features
- HP Real Life Technologies
- TWAIN
Media Handling
- Max Document Size
- 216 mm x 311 mm
- Manual
- USB 2.0
- Included Accessories
- Transparency adaptor, film holder
- Cables Included
- 1 x USB cable
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- UL, BSMI, GOST, cUL, CCC, MIC, FCC, IEC 60950-1, ACA
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 25 Watt
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- MacOS X 10.3.9 or later - PowerPC G3 RAM 128 MB - HD 250 MB (USB) , Windows 2000/XP - Pentium II - 233 MHz - RAM 128 MB - HD 500 MB (USB)
- 30.3 cm
- 50.8 cm
- 9.8 cm
- 4.4 kg
- 10 °C
- 35 °C
- 0 - 90%
