Integrate this 297 x 431 mm flatbed scanner into your office. Create custom workflow profiles using HP Smart Document Scan Software and scan with confidence at up to 50 ppm/100 ipm. Use the 200-page automatic document feeder for big scan jobs.
Scanning for a more productive office
Get quick, precise document scans in black-and-white, greyscale and colour at up to 50 ppm/100 ipm.Scan documents unattended using the 200-page automatic document feeder.Accurately capture scans of mixed stacks with various weights and sizes using HP EveryPage technology.Reliably capture large volumes of high-quality images with the 5,000-page daily duty cycle. -
Scan large-format documents and bulky items
Scan both sides of a page at the same time in a variety of media sizes up to 300 x 864 mm (11.8 x 34 inches).Use the A3 flatbed to scan thick, bound materials or other items that can't go through the document feeder.Centrally monitor and control this scanner with industry-leading HP Web Jetadmin. -
Easily integrate workflow solutions
Scan and integrate into document management applications using TWAIN, ISIS and WIA drivers.Create custom workflow profiles and assign them to quick-start buttons for easy access to repeated tasks.Send scans to the cloud or SharePoint sites and add metadata for easy search, archiving and sharing.Track scanned documents with customized messages or page numbers with a built-in ink imprinter. -
Built-in features deliver the results you need
Capture data you can edit with built-in OCR capabilities, then save scans in a variety of file formats.Enhance scans using features such as automatic deskew, rotate, crop, blank page removal and size formatting.Automatically improve the accuracy of scanned images with included Kofax Virtual ReScan Pro software.
- HP ScanJet Enterprise Flow N9120 Flatbed Scanner - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Light Source
- Xe-gas cold cathode fluorescent lamp
- Max Supported Document Size
- 300 x 864 mm
- Localisation
- English, German, French, Italian, Spanish / Europe
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 50 ppm (mono) / 50 ppm (colour)
- Max Document Size
- 300 mm x 864 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, bulk objects (such as books, magazines and other bound materials), business card, photo
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 200 sheets
- Duty Cycle
- 5000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
- 69.2 cm x 55.8 cm x 33.8 cm
- 37 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
- 300 x 864 mm
- Localisation
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 600 dpi x 600 dpi
- CCD
- Bulb / Light Source Type
- Max Document Scan Speed B/W
- 50 ppm
- Max Document Scan Speed Colour
- 50 ppm
- Control Panel Buttons Functions
- Scan, copy, power save, cancel, tools
- Duty Cycle
- Scanner Speed Details
- 50 ppm black & white (back) - A4 / Letter - 200 dpi , 100 ipm - colour - A4 / Letter - 200 dpi , 50 ppm black & white (back) - A4 / Letter - 200 dpi , 50 ppm - colour - A4 / Letter - 200 dpi , 100 ipm - greyscale - A4 / Letter - 200 dpi , 50 ppm - greyscale - A4 / Letter - 200 dpi , 40 ppm - black & white - A4 / Letter - 300 dpi , 40 ppm - greyscale - A4 / Letter - 300 dpi , 80 ipm - black & white - A4 / Letter - 300 dpi , 80 ipm - greyscale - A4 / Letter - 300 dpi , 40 ppm - colour - A4 / Letter - 300 dpi , 78 ipm - colour - A4 / Letter - 300 dpi
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 300 mm x 864 mm
- Supported Document Size Details
- ADF - up to 300 x 864 mm , Flatbed - up to 297.2 x 431.8 mm
- Automatic
- 200 sheets
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- UL, BSMI, GOST, cUL, DEMKO, NOM, CCC, EMC, MIC, EK, FCC, IEC 60950-1, ACA
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
- 112 Watt
- Software Included
- Readiris Pro, HP Web JetAdmin, Kofax VirtualReScan Professional
- OS Required
- System Requirements Details
- Windows Vista/7/8 - 2 GHz - RAM 2 GB - HD 150 MB , Windows XP - 1.6 GHz - RAM 1 GB - HD 150 MB , Windows 2000 - 1.3 GHz - RAM 512 MB
- 69.2 cm
- 55.8 cm
- 33.8 cm
- 37 kg
- Shipping Width
- 84.8 cm
- Shipping Depth
- 71.6 cm
- Shipping Height
- 54 cm
- Shipping Weight
- 46.3 kg
- Limited warranty - 1 year
- 10 °C
- 35 °C
- 15 - 80%
