Product
Brand
HP Scanjet Enterprise Flow N9120 Flatbed Scanner
Quicklinx: 9HDHWS00 Mfr#: L2683B#B19
  • Windows 8 (32/64 bits)
Integrate this 297 x 431 mm flatbed scanner into your office. Create custom workflow profiles using HP Smart Document Scan Software and scan with confidence at up to 50 ppm/100 ipm. Use the 200-page automatic document feeder for big scan jobs.
HP ScanJet Enterprise Flow N9120 Flatbed Scanner - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Light Source
Xe-gas cold cathode fluorescent lamp
Max Supported Document Size
300 x 864 mm
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 48-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
50 ppm (mono) / 50 ppm (colour)
Max Document Size
300 mm x 864 mm
Automatic Duplexing
Supported Document Type
Plain paper, bulk objects (such as books, magazines and other bound materials), card scanner, photo
Document Feeder Type
Automatic
Document Storage Capacity
200 sheets
Duty Cycle
5000 scans per day
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
69.2 cm x 55.8 cm x 33.8 cm
37 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Interface Type
USB 2.0
300 x 864 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
CCD
Bulb / Light Source Type
Max Document Scan Speed B/W
50 ppm
Max Document Scan Speed Colour
50 ppm
Control Panel Buttons Functions
Scan, copy, power save, cancel, tools
Duty Cycle
5000 scans per day
Scanner Speed Details
50 ppm black & white (back) - A4 / Letter - 200 dpi , 100 ipm - colour - A4 / Letter - 200 dpi , 50 ppm black & white (back) - A4 / Letter - 200 dpi , 50 ppm - colour - A4 / Letter - 200 dpi , 100 ipm - greyscale - A4 / Letter - 200 dpi , 50 ppm - greyscale - A4 / Letter - 200 dpi , 40 ppm - black & white - A4 / Letter - 300 dpi , 40 ppm - greyscale - A4 / Letter - 300 dpi , 80 ipm - black & white - A4 / Letter - 300 dpi , 80 ipm - greyscale - A4 / Letter - 300 dpi , 40 ppm - colour - A4 / Letter - 300 dpi , 78 ipm - colour - A4 / Letter - 300 dpi
TWAIN, ISIS, WIA
Media Handling
Max Document Size
300 mm x 864 mm
Supported Document Size Details
ADF - up to 300 x 864 mm , Flatbed - up to 297.2 x 431.8 mm
Automatic
200 sheets
USB 2.0 - Type B
1 x USB cable
UL, BSMI, GOST, cUL, DEMKO, NOM, CCC, EMC, MIC, EK, FCC, IEC 60950-1, ACA
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
112 Watt
Software Included
Readiris Pro, HP Web JetAdmin, Kofax VirtualReScan Professional
System Requirements Details
Windows Vista/7/8 - 2 GHz - RAM 2 GB - HD 150 MB , Windows XP - 1.6 GHz - RAM 1 GB - HD 150 MB , Windows 2000 - 1.3 GHz - RAM 512 MB
69.2 cm
55.8 cm
33.8 cm
37 kg
Shipping Width
84.8 cm
Shipping Depth
71.6 cm
Shipping Height
54 cm
Shipping Weight
46.3 kg
Limited warranty - 1 year
10 °C
35 °C
15 - 80%
