Enhance performance and streamline workflow, using a fast, reliable scanner. The compact, efficient footprint of this PC-connected device saves energy, while producing consistent, high-quality images in black-and-white, greyscale or colour.
- HP ScanJet Enterprise 7000 s2 Sheet-feed Scanner - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Light Source
- LED
- Max Supported Document Size
- 216 x 3098 mm
- Localisation
- English, German, French, Italian, Spanish / Europe
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 48-bit colour
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 45 ppm (mono) / 45 ppm (colour)
- Max Document Size
- 216 mm x 3098 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, business card, plastic card, labels
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 3000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP SP3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
- Microsoft Certification
- Compatible with Windows 7
- 31 cm x 18.1 cm x 18 cm
- 5.35 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
- 216 x 3098 mm
- Localisation
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 48-bit colour
- 600 dpi x 600 dpi
- CCD
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 45 ppm
- Max Document Scan Speed Colour
- 45 ppm
- Duty Cycle
- Scanner Speed Details
- 90 ipm - duplex black & white (back) , 90 ipm - duplex - colour - A4 / Letter , 45 ppm - duplex black & white (back) , 45 ppm - duplex - colour - A4 / Letter
- Scanner Features
- Color Dropout, Blank Page Removal, Ultrasonic Multi Feed Detection, 2 line x 16 character LCD
- TWAIN, ISIS
Media Handling
- Max Document Size
- 216 mm x 3098 mm
- Supported Document Size Details
- ADF - up to 216 x 3098 mm
- Automatic
- 50 sheets
- USB 2.0 - Type B
- Included Accessories
- Cleaning cloth
- Cables Included
- 1 x USB cable
- C-Tick, BSMI, CISPR 22 Class A, GOST, CISPR 22 Class B, CISPR 24, cUL, SASO, EN 61000-3-3, CCC, EMC, FCC, UL 60950-1 Second Edition, KCC, CSA C22.2 No. 60950-1 Second Edition, IEC 60950-1 Second Edition, NRTL
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 42 Watt (1.822 Watt)
- Software Included
- Readiris Pro, Kofax VirtualReScan Professional, Nuance PaperPort, HP Smart Document Scan Software, Cardiris Pro
- OS Required
- System Requirements Details
- Windows 7/Vista - 2 GHz - RAM 2 GB - HD 150 MB (USB 2.0) , Windows XP SP3 - 1.6 GHz - RAM 1 GB - HD 150 MB (USB 2.0)
- 31 cm
- 18.1 cm
- 18 cm
- 5.35 kg
- Shipping Width
- 39.9 cm
- Shipping Depth
- 30.3 cm
- Shipping Height
- 27.8 cm
- Shipping Weight
- 7.4 kg
- Limited warranty - 1 year , Technical support - phone consulting - 1 year - response time: 24 hours
- 10 °C
- 35 °C
- 15 - 80% (non-condensing)
