Perform fast document scanning at up to 25 ppm – load up to 50 pages into the automatic document feeder for easy and reliable single or double-sided scanning. Get high quality image scanning too, including 35 mm slides and negatives.
Get fast document scanning and professional results for images and graphics
Get fast, unattended document scanning at up to 25 ppm with a 50-page automatic document feeder. Get professional-quality scans of graphics, photos, slides or negatives at up to 4800 dpi. -
Launch common tasks for increased productivity with one-touch function buttons
One-button activation allows fast scanning of photos and documents. Easily create, save, e-mail, copy and launch scans of photos or documents. Get started with plug-and-play installation that seamlessly integrates into existing software. -
Ensure high quality results and easy integration into existing document management systems
Integrate with existing document management systems using ISIS and TWAIN drivers. Organise documents with ScanSoft PaperPort. Edit images with Adobe Photoshop Elements. Compliant with Kofax VRS (not included) for superb scan quality.
- HP ScanJet 8270 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Max Supported Document Size
- Legal (216 x 356 mm)
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 48-bit colour
- Optical Resolution
- 4800 dpi x 4800 dpi
- Max Document Scan Speed
- 25 ppm (mono)
- Max Document Size
- 216 mm x 356 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, slides, film
- Document Feeder Type
- Manual, automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Apple MacOS 9.1, Apple MacOS X 10.2, Microsoft Windows 2000 / XP, Apple MacOS X 10.3
- Microsoft Certification
- Certified for Windows Vista
- 57.4 cm x 39.9 cm x 19.6 cm
- 8.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 48-bit colour
- CCD
- Max Document Scan Speed B/W
- 25 ppm
- Control Panel Buttons Functions
- Scan, copy, email, file, edit text, power save, cancel
- Scanner Speed Details
- 28 sec/scan - photo - colour - 10x15cm , 4 sec/scan - preview , 36 sec/scan - OCR - Letter , 25 ppm - black & white - Letter , 5.5 ipm - duplex - Letter
- TWAIN, ISIS
Media Handling
- Max Document Size
- 216 mm x 356 mm
- Manual, automatic
- 50 sheets
- Slots
- 1
- USB 2.0
- Included Accessories
- Transparency adaptor
- Cables Included
- 1 x USB cable
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- UL, TUV GS, BSMI, cUL, NOM, IEC 60950, CCC
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 80 Watt
- Software Included
- Adobe PhotoShop Elements, Presto! PageManager, Readiris Pro, ScanSoft PaperPort, HP Photosmart Premier, HP Photosmart Essential
- OS Required
- System Requirements Details
- Windows 98SE/2000/ME/XP - Pentium II RAM 64 MB - HD 175 MB (USB) , MacOS 9.1 or later - PowerPC - 233 MHz - RAM 64 MB - HD 240 MB (USB) , MacOS X 10.1.5 or later - PowerPC - 233 MHz - RAM 128 MB - HD 240 MB (USB)
- 57.4 cm
- 39.9 cm
- 19.6 cm
- 8.6 kg
- Shipping Width
- 63.8 cm
- Shipping Depth
- 37.3 cm
- Shipping Height
- 46.4 cm
- Shipping Weight
- 12.9 kg
- Limited warranty - 1 year
- 5 °C
- 40 °C
- 15 - 80%
