Save time with fast scanning speeds and intuitive controls. Set up quickly, using a single cable. Enjoy high-resolution document detail. One-touch scan-to buttons let you start working and sharing fast. Place this compact scanner almost anywhere.
Stay productive with high-quality, versatile document scanning
Finish jobs faster – scan a one-page A4 document in as fast as 14 seconds at 200 dpi resolution, or scan a 10 x 15 cm (4 x 6-inch) photo in as fast as 21 seconds at 200 dpi resolution.Copy documents quickly using the one-touch copy button.Save time with easy-to-use controls. Plug in and set up fast, using a single cable.Get precise results when you scan important documents and images. Capture crisp detail at up to 4800 x 4800 dpi resolution, 48-bit colour. -
Scan and archive documents with ease
Save time with convenient one-touch scanning capabilities. Capture and send images directly to email or PDF – and print or copy images in a touch.Scan multiple items at once – including business cards, receipts, and photos, and automatically save them as separate files.Create the prints you need: use the ArcSoft PhotoStudio 6 photo-editing software included to easily edit, search, and organise images for printing in multiple sizes. -
Save valuable space in your office with this compact scanner that fits almost anywhere
Set up and work where you want: this compact, landscape-oriented scanner can fit almost anywhere in your office.Scan books, journals, and bound materials with ease, using the scanner's floating-hinged lid for high clearance.Eliminate the need for a power cable – this USB-powered scanner saves energy by plugging directly into your PC.
- HP ScanJet 300 Flatbed Photo Scanner - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Light Source
- LED
- Max Supported Document Size
- 216 x 297 mm
- Localisation
- English, German, French, Italian, Spanish / Europe
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 48-bit colour
- Optical Resolution
- 4800 dpi x 4800 dpi
- Max Document Size
- 216 mm x 297 mm
- Supported Document Type
- Plain paper, photo
- Document Feeder Type
- Manual
- Duty Cycle
- 26000 scans per day
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X Lion 10.7, Windows 8, Apple MacOS X 10.6.8, Apple OS X 10.8 Mountain Lion, Microsoft Windows XP SP2 (32 bit)
- 37.3 cm x 27.4 cm x 4.45 cm
- 1.76 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 216 x 297 mm
- Localisation
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 48-bit colour
- Bulb / Light Source Type
- LED
- Control Panel Buttons Functions
- Scan, copy, Scan-to-Email, Scan-to-PDF
- Duty Cycle
- Scanner Speed Details
- 21 sec/scan - photo - colour - 10x15cm - 200 dpi , 30 sec/scan - OCR - A4
Media Handling
- Max Document Size
- 216 mm x 297 mm
- Manual
- Interfaces Details
- USB 2.0
- Cables Included
- 1 x USB cable
- C-Tick, BSMI, CISPR 22 Class B, CISPR 24, SASO, EN55022 Class B, CCC, EMC, FCC, UL 60950-1 Second Edition, KCC, CSA C22.2 No. 60950-1 Second Edition, IEC 60950-1 Second Edition, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009
- ENERGY STAR Certified
- Power Consumption Operational (Standby)
- 2.5 Watt (0.5 Watt)
- Software Included
- Drivers & Utilities, ArcSoft PhotoStudio 6
- OS Required
- System Requirements Details
- Windows 7/Vista - 1.3 GHz - RAM 1 GB - HD 1 GB (USB) , Windows 7 64-bit Edition - 1.3 GHz - RAM 2 GB - HD 1 GB (USB) , Windows Vista 64-bit Edition - 1.3 GHz - RAM 2 GB - HD 2 GB (USB) , Windows XP SP2 - 1.3 GHz - RAM 512 MB - HD 600 MB (USB)
- 37.3 cm
- 27.4 cm
- 4.45 cm
- 1.76 kg
- Shipping Width
- 43.4 cm
- Shipping Depth
- 33.5 cm
- Shipping Height
- 8.6 cm
- 10 °C
- 35 °C
- 15 - 80% (non-condensing)
